It is currently Fri Jul 18, 2025 10:33 am
 Post subject: Rego Test Monday
PostPosted: Fri Mar 10, 2006 9:10 am
Well guys she's booked in for the Rego test on Monday. So we will find out whether I can dispense with these bloody Unregistered Vehicle Permits...More on Monday.
Matt
 Post subject: Re: Rego Test Monday
PostPosted: Fri Mar 10, 2006 9:11 am
Matt
goodluck!!!
Bling me up Scotty!
PostPosted: Fri Mar 10, 2006 2:31 pm
Matt,
Good Luck, hope all goes well on Monday.
Dan
PostPosted: Fri Mar 10, 2006 2:47 pm
Matt
no luck needed mate you have done the hard yards and sweat and effort and blood has been spent, you have made the engineer happy its just formallity now :D
Jon
PostPosted: Fri Mar 10, 2006 3:53 pm
What is it that they will be 'testing'?
JC
PostPosted: Fri Mar 10, 2006 5:04 pm
usual lights/horn/brakes/wipers ?
Pays to get there early & check the lights before you go in first!
Sucks to fail because of 1 brake light. Been there done that :roll:
 Post subject: Yep
PostPosted: Fri Mar 10, 2006 6:28 pm
Good advice from the West :wink: ...and jam those brakes on hard on the rollers ( 8) )....helps if the tyres fairly well scrubbed in....
See you on the road :!: :D
PostPosted: Fri Mar 10, 2006 7:03 pm
Funny story,
I took my 1600 over the pits when i installed a CA18 many years ago. The inspector told me to stand on the brakes which i did, he asked me again to stand on the brakes, at this stage i knew i had a problem because the brake pedal was hard up against the firewall?? I pumped the brake pedal and the inspeector passed me (without realising what had happen) I went home and looked over the brake system to find the master cylinder had begun to fail and i had an engine bay full of brake fluid. I suppose i was happy not to have lost the brakes all together and after i rebuilt the master cylinder i never had a problem.
Dan
PostPosted: Sat Mar 11, 2006 7:15 pm
Matt,
All will go well, and you will legal and mobile once again.
Its been a long road, and thanks for giving me the honour of sharing it with you.
Cheers Mate, :wink:
Andrew
PostPosted: Sat Mar 11, 2006 9:08 pm
Thanks Andrew, that a very nice thing to say. My pleasure. And thanks for the encourage to all. Well its Saturday and tomorrow is Wheels 2006 where the Minstar will go on display so it should interesting to see what people have to say. No doubt, you will hear my delight should they pass me up in Sydney!
Matt
PostPosted: Sun Mar 12, 2006 5:03 pm
Good Luck Matt...
I am sure all will be perfect
Baracade
PostPosted: Mon Mar 13, 2006 3:58 pm
Well did it get the OK :D
PostPosted: Mon Mar 13, 2006 6:42 pm
i'm guessing you are all passed? i would consider that your probably out giving the ricers of canberra a hard time?
and a few conversions:
13B Extend in a 1600
PostPosted: Mon Mar 13, 2006 10:45 pm
Nah guys, a fail. But all is not lost, all the issues are very minor. The only fly in the ointment is that by cutting off the cowl for the original radiator i removed the chasis number so now i have to have the car ID checked as well. Even though it has been previously registered, and the chasis number appears on the compliance plate? V Strange. So I will fix up the small issues and I should be home free. One of the guys ended up asking me 20 questions about the car such as "Why'd you do it", which struck me as a pretty stange question. But anyway, I am feeling quite positive about the outcome and she should be registered by next week I would say.
Matt
PostPosted: Tue Mar 14, 2006 7:35 am
Sorry to hear :(
you should look at it in a good way (I guess its only going to make your car better and safer) :)
57 Morris minor
88 Rover Mini
