It is currently Sat Jul 19, 2025 12:59 am
PostPosted: Sat Aug 05, 2006 7:55 pm
if so wich ones can be done?
PostPosted: Sat Aug 05, 2006 9:39 pm
here's one on ebay, but that front suspension puts up warning bells all over the place for me. Could well be that the gearbox is too wide to fit between the standard subframe suspension towers, but mounting it off the subframe isn't the solution
http://cgi.ebay.com.au/Mini-clubman-SR1 ... dZViewItem
I'd like to have a go at a GTIR one day, but it's over the registerable capacity limit
I'm dieing to see someone try a Nissan March (Micra) Super Turbo (supercharged & turbo charged)
PostPosted: Sat Aug 05, 2006 10:58 pm
That guy has messed up the whole geometry of the car..look at the tierod and suspension placement :shock:
PostPosted: Sun Aug 06, 2006 12:09 am
I had to google that one, as I'd never even heard of the car.
An owner writes:
The supercharger on the March ST has a differential by pass valve which compares its boost to the turbo and slowly opens when the turbo boost exceeds that of the supercharger, then switching off the supercharger allowing a smooth transition between the two. Its not perfect but it does work pretty damn well. I know - I own one! Just out of interest I just had my march ST dyno'ed at 171bhp@5500 rpm. Thats from a 930cc engine..
PostPosted: Sun Aug 06, 2006 11:44 am
Geez Will... Catch up...
http://autospeed.drive.com.au/cms/A_2216/article.html
http://www.j-garage.com/nissan/march/st.htm
i'd try the suzuki alto worx myself....
