It is currently Mon Aug 18, 2025 10:36 pm
PostPosted: Thu Dec 10, 2009 8:32 pm
That's interesting , as mentioned above i have the nitro kyosho from a similar time (early 90's) and it is a completely different chassis , basic plastic tub . Please let me know if you ever want to sell the spare chassis .
PostPosted: Thu Dec 10, 2009 11:38 pm
Tomboss Breweros
I have 2 Tamiya minis, the 1/8 nitro and the 1/10 electric.
The nitro has a .15 engine instead of .12 and i upgraded it to a 2 speed gearbox, then 1st gear stripped so i put in a gearset for a higher top speed, it was good for about 80 - 85, you cant do that for long tho.
It needs a front suspension arm kit and new body.
The electric is standard other than a stronger front suspension setup from the next model up.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Dec 11, 2009 7:38 pm
Ian I saw the pics you put on here.I will keep you in mind for the chassie.
Tombo was the .15 engine a Tamiya one or aftermarket?
Mine has an OS engine.....I would like to get the 2 speed box. Do you get to drive it much?
Might bring mine to Hay????
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
NZ 79 1275gt clubman estate
79 LE
80 meanee
Racecar
Fiat 500
PostPosted: Fri Dec 11, 2009 7:43 pm
thank's :)
