creekman wrote:
Hi, been thinkin about putting "Ike" back together with an 84 mm stroke, think I have a virgin big journal crank in my wrecked 1300 auto. If the stroke is increased by 3mm does that mean 3mm has to come off the top of the pistons, if so can hypertecs cope with that? Haven't found any S rods yet so that's a stumbling block, saw some bent ones on Ebay, are they straightenable (about 4mm bent)? Been reading the mod threads , very interesting, you guys are great. Cheers, Dave.
you only need to take 1/2 the stroke increase off the pistons.
Mine has a 84.33mm stroke (up by 3.0mm), we took 1.5mm off em. They are 73.0mm Hypatecs.
Yes S rods can be straightened. They are usually bent when you do check em.. mine all were a bit. But 4mm is a lot.
Graham Russell (in Sydney) can do them. Any reco shop over there would have the gear.
<edit> as for squish, I aim for .010" piston to deck clearance on fast roady motors.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
