1380 yellow devil wrote:
So it is recomended to get these rockers and instead of getting the 1.5 Rollers that cost $$$$$$$$.
You can get more valve lift (without changing cam) is a few ways:
1. Put offset bushes in your S or pressed steel rockers, & move the shaft back 1.5mm as per Vizard. Gives you another .030"-.040" valve lift over stock. Ozmotorsport has a set of these in that I did years ago. But the bushes are NLA now, and need to be made. Rocker ratio is around 1.3. More stuffing about to do than <2> below.
2. Build a set of Toyota Corolla ones as per this thread. These rockers are cheap, but by the time you get someone to make the bushes, mod the rockers, make new posts, get a HD rocker shaft etc, fit it all up you are looking at around $300+, unless you do yourself.
3. Fit MiniSpares forged (or cast?) 1.5 rockers. I'm running these, no wear on rockers valves or guides in a couple of years. Cost $500+ at Karcraft. Less if you import, check MiniSpares- p/no C-AEA436. Ratio is around 1.55-1.58, better than 1.5 rollers.
4. Fit roller tip rockers (bling-bling you can't see..). The ones I've worked on here (MiniSport) had sloppy bushes when bought, and the rollers got flats on them in 10,000km. Ask gareth_1330
Cost is getting towards $600 for MiniSpares ones (which may be better made), from Karcraft.
5. Fit full roller rockers. No better than the others for the street, and priced from $600+ to $heaps!.
Import.
6. Yella Terra make roller rockers here for A series but no idea of cost.
