It is currently Mon Jun 30, 2025 9:20 am
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Mon Jan 10, 2005 10:29 pm
Ow Kev I love my little stash on my left at the moment :shock: :lol: 8)
PostPosted: Tue Jan 11, 2005 12:33 pm
So it is recomended to get these rockers and instead of getting the 1.5 Rollers that cost $$$$$$$$.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Tue Jan 11, 2005 7:08 pm
You can get more valve lift (without changing cam) is a few ways:
1. Put offset bushes in your S or pressed steel rockers, & move the shaft back 1.5mm as per Vizard. Gives you another .030"-.040" valve lift over stock. Ozmotorsport has a set of these in that I did years ago. But the bushes are NLA now, and need to be made. Rocker ratio is around 1.3. More stuffing about to do than <2> below.
2. Build a set of Toyota Corolla ones as per this thread. These rockers are cheap, but by the time you get someone to make the bushes, mod the rockers, make new posts, get a HD rocker shaft etc, fit it all up you are looking at around $300+, unless you do yourself.
3. Fit MiniSpares forged (or cast?) 1.5 rockers. I'm running these, no wear on rockers valves or guides in a couple of years. Cost $500+ at Karcraft. Less if you import, check MiniSpares- p/no C-AEA436. Ratio is around 1.55-1.58, better than 1.5 rollers. :P
4. Fit roller tip rockers (bling-bling you can't see..). The ones I've worked on here (MiniSport) had sloppy bushes when bought, and the rollers got flats on them in 10,000km. Ask gareth_1330 :cry:
Cost is getting towards $600 for MiniSpares ones (which may be better made), from Karcraft.
5. Fit full roller rockers. No better than the others for the street, and priced from $600+ to $heaps!.
Import.
6. Yella Terra make roller rockers here for A series but no idea of cost. :lol:
Last edited by drmini in aust on Thu Feb 19, 2009 6:18 pm, edited 2 times in total.
PostPosted: Wed Jan 12, 2005 8:46 am
Thanks Dr
I Think I will give it a go on the ToJo Ones I can get the machine work done a a good price.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Wed Jan 12, 2005 9:39 pm
My ToyoMini ones are going on Barney the Pretend S (1293A+).
I found there's `not a lot of clearance' :shock: between the back of the rockers and the alloy rocker cover, so today I linished them back to level with the nuts. :wink:
PostPosted: Wed Jan 12, 2005 10:10 pm
PostPosted: Wed Jan 12, 2005 10:21 pm
Dunno what your :?: means.. so..
`Linisher' is like a bench grinder but uses a sanding belt.. neater job.
The rockers were a bit long, now that end is a little shorter!
The `nuts' are the locknuts on the rockers.. :lol:
PostPosted: Wed Jan 12, 2005 10:42 pm
do you think that will impare the strength of the rockers at all?
68matic: "i havent seen much head in my life "
 Post subject: Clearance
PostPosted: Thu Jan 13, 2005 3:29 am
Any clearance issues likely with a std rocker cover?
Kevin.
PostPosted: Thu Jan 13, 2005 6:11 am
No. They are very thick & rough there, and a lot of it is just casting/forging flash. They are still pretty thick.
Most stress on rockers is around the arm/boss area.
1310/71, I'll let you know. Yes there was before I did this mod. If still is it might give you an excuse to get a Bling! alloy one.. :wink:
BTW ,with alloy covers it's pretty easy to mill the attachment holes forward a mm or 2, and then push the cover back a bit. There are no clearance issues at the front, usually. 8)
PostPosted: Fri Jan 28, 2005 8:39 pm
Here's a pic of the Corolla rockers on a relocated Mini shaft- BEFORE I linished them at pushrod end. :wink:
Last edited by drmini in aust on Mon Jul 11, 2005 7:26 pm, edited 1 time in total.
PostPosted: Sat Jan 29, 2005 4:01 pm
Corolla rockers now installed on the 1293A+, ready to fit in car. Maybe this week..
Pushrods are pretty close to the back of the pushrod holes in head, but they miss... just! :wink:
They also (now I've linished them ) just miss a stock steel rocker cover.
PostPosted: Sat Jan 29, 2005 5:40 pm
Why don't you cut up a rocker cover and widen it through the area in question?
Chris
Everything I like is either
PostPosted: Sat Jan 29, 2005 5:43 pm
Because I have an alloy one going on there. It will miss OK. :wink:
Rockers are plenty strong- I only removed the forging flash etc from the back of them. They are still as thick as S ones. :lol:
PostPosted: Sat Jan 29, 2005 7:18 pm
Mine's a std one that's been chromed (bling Bling 8) )
So we'll have to linish my set fairly well. :)
