CLUBMAN wrote:
is it using the same block at the 1310 special?
what is being done while its apart?
Nope- this time it's a 1275 auto block, we bored it from 1293 straight to 1360..
Block has modified oilways to suit manual box.
I'll use the same big ported head, a `revised' RE-13 cam, and an S crank & rods again.
I've got the block back, now need to strip my other motor to get S crank & rods, get 'em balanced with flywheel etc, fit pistons and chuck together.
Box is the same MK2 S, but it might just get the 3.44 diff swapped out for a 3.647. Gotta outdrag kazjim more down the straight at Wakefield Pk..
