It is currently Fri Jul 18, 2025 9:49 pm
PostPosted: Fri Jan 22, 2010 8:49 am
rathcoole wrote:
Try buying helical close ratio dog box :)
I believe I had one!
I picked up a 3 synch gearbox with a deluxe I bought in 92. When I had it rebuilt the laygear number spun me out so I had a closer look. I've got no idea of its reason for existance, but there you go.
Here's the details from the teeth count I took at the time:
22G210
Top 1.040 : 1
Third 1.190 : 1
Second 1.705 : 1
First 2.46 : 1
Reverse 2.46 : 1
PostPosted: Fri Jan 22, 2010 9:36 am
Sounds like the original S 3 sync close ratio helical.
1st & Reverse 2.568
2nd 1.780
3rd 1.242
from Mk1 Performance conversions top of the second page
Alternative gearing available as factory option for gearboxes based on 22G392 mainshaft (which have late B-type as originally for 22G232 laygear based boxes) for Cooper and S only:
* C-22G210 (helical cut close ratio)
* C-22G335 (straight cut standard ratios)
* C-22G306 (straight cut close ratio) (was replaced by 22G1047)
The original laygears are marked with the appropriate 22Gxxx number
not a dog box though! :wink: but a very nice score!!! :shock:
Kevin
PostPosted: Fri Jan 22, 2010 10:29 am
Ah yeah, I forgot about the dog box bit....
it was an odd find..
PostPosted: Fri Jan 22, 2010 1:46 pm
Curly wrote:
Not a turn off at all :) , but it would get wearing day in and day out on the road or a long trip.
If you listen carefully you can hear the high pitched whine above the induction and engine noise here:
http://www.youtube.com/user/Curly948#p/u/7/lMGMrqiLNlw
I'm with curly - Actually I'm a bit dissapointed I can't hear mine over the induction noise - http://www.youtube.com/watch?v=K1a__sOTPyM
PostPosted: Fri Jan 22, 2010 8:32 pm
This guy can:
http://www.youtube.com/watch?v=hUJvpWwLmHM
PostPosted: Fri Jan 22, 2010 8:59 pm
Curly wrote:
Maxi23 wrote:
Is noise really that much of a turn off .
How much noise do they make ?
I was very impressed with that video, nice driveing.
We have a S/C 3 snc gearbox in the race car with std drop gears and diff crownwheel & pinion (modified for LSD) We recently had a new crownwheel & pinion made that is S/C and it has made a noticable difference to the sound, much louder now. I have also just obtained a genuine S/C drop gear set that I will use shortly (PI in March) so we'll see how much more noise it makes with them twirling around. :D
Have a Nice Day.
PostPosted: Sat Jan 23, 2010 9:29 am
1st & Reverse 2.568
2nd 1.780
3rd 1.242
Kevin
This CR helical gear set is fitted to the original gearbox of my Black Mk 1 S. Very nice gears on the road.
Steve
PostPosted: Sat Jan 23, 2010 1:04 pm
Is it true that some of the older SCCR gearsets need to run bronze competition baulk rings (which are now NLA)?
I have a set of SCCR gears here, the cone bits don't appear to be titanium nitrided or whatever the coating was.
