It is currently Fri Jul 18, 2025 11:57 pm
Post new topic Reply to topic  [ 452 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 31  Next
PostPosted: Fri Jul 30, 2004 10:25 pm
I hosted some pics of Animal's 1st set (Honda Accord 9" ventilated) and they looked pretty good. 8)
Here's some pics.. again..
Enjoy! :wink:
PostPosted: Sun Aug 01, 2004 4:36 pm
Just got back from tha wreckers where I picked up a 2 sets of calipers and ONE disk. I'd be b***ered if I could pull the hub on the drivers side. Got about half way and stuck Even used the BFH with no luck. The passenger side just came off normal. I ran out of time as they were closing,
Best part though is when I went to pay the guy says "How much were you quoted?" and I said $25 (forgot to say per wheel :wink: ) and that is all he took :roll:
PostPosted: Sun Aug 01, 2004 5:43 pm
Good deal!
For a step by step how-to, see thread
http://ausmini.tziworld.com/viewtopic.php?p=13741#13741
PostPosted: Sun Aug 01, 2004 10:17 pm
Kevin have you seen this site? http://www.dba.com.au/dba_catalogue_2004/HTML/Standardseries/standard_index.htm
The disc rotors I picked up are DBA188 - would there be any advantage to get the correct Mini versions or wont they fit? Or if staying with the Honda pick up some new discs that are closer to the finished diameter required?
PostPosted: Sun Aug 01, 2004 10:25 pm
Yeah I've got it. I think we used #191- 44mm wide x 12mm thick.
If you go with 12" wheels leave them stock diameter. If going with 10" wheels turn them down to 7.9".
No good using S discs, totally different- they won't fit your drum drive flanges or CVs...
PostPosted: Sun Aug 01, 2004 10:35 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey doc what about for 13's
makka
PostPosted: Sun Aug 01, 2004 10:41 pm
Yep, for 13" too, leave 'em stock. 9" they are... and they don't 'arf stop... 8)
PostPosted: Mon Aug 02, 2004 8:31 pm
how much dif is there in stopping power between the 10" wheeled ones and stock size ones?
PostPosted: Mon Aug 02, 2004 9:06 pm
I good question. I'm still tossing up between 12" and 10" wheels. This is the order which I"m prioritising:
1) No Flares. I really don't want flares.
2) 10" wheels. They look more 'original' and the superlights look better as 10's than 12's I reckon.
3) Price. Extra cost/effort involved in modifying the calipers/pads to go underneath 10" wheels compared with just leaving the whole setup stock when you go under 12" wheels.
4) Stopping power. I don't drive it that hard and they'll kick arse over drummies.
So ultimately I'd like no flares and 10" x 5" Performance Superlites. How much extra effort is involved in getting the brakes under 10's and how much stopping power do I loose?
dewey
dwightgunning.com
PostPosted: Mon Aug 02, 2004 9:45 pm
To fit Hondas (turned down to 7.9") under any 10" mag wheel you are looking at spacers. 25mm for Contessas (Mini offset- S ones won't fit), 19mm for Speedy Hotwires (as they are offset out more- about 1/4"). A little bit of grinding is needed to the pad bracket, pin lugs/caliper and the outer pad. No big deal- no fluid in this part.
You WILL need flares though.
12" Performance mags will bolt straight on stock 9" discs without any spacer, you won't need flares as it's all further inside the wheel. If you detest flares, this would be my choice.
Either system without servo will stop better than S ones without servo, on the road at least. Nobody's hit the track with them yet that I know of. :wink:
PostPosted: Mon Aug 02, 2004 10:06 pm
thanks doc, i reacon il turn them down then once i get some. that way il be able to use 10's on the track and 12's for the road.
the cheepest iv been quoted is $39.50 per rotor, anyone know of cheeper ones?
thanks
PostPosted: Mon Aug 02, 2004 10:20 pm
Is that for new ones or s/h?
If new, that's 1/2 the price of S rotors... :twisted:
PostPosted: Mon Aug 02, 2004 10:27 pm
new ones. 8)
PostPosted: Tue Aug 03, 2004 9:27 am
Where was that price from? the cheapest i have been quoted for dba rotors are 90 each. that was from burson.
PostPosted: Tue Aug 03, 2004 1:31 pm
hbt performance part.
http://stores.ebay.com.au/HTB-PERFORMANCE-PARTS_Brake-Rotors-For-All-Cars_W0QQcolZ2QQdirZQ2d1QQsclZallQQsotimedisplayZ2QQtZkm
Users browsing this forum: No registered users and 34 guests
