It is currently Mon Aug 18, 2025 7:23 pm
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 26  Next
PostPosted: Fri Mar 18, 2005 9:16 pm
benjamin wrote:
ok so ill need the coil and dissy and cap is there anyting else ill need as i might have a look in blaxland wreckers tommorow :)
Make sure the cap and rotor is OK, if they're worn you can get new ones from Repco, Auto One, Pep's etc.
Info how to mod it is on p1 of this thread. :wink:
PostPosted: Sat Mar 19, 2005 11:40 am
Picked up another one today...Pick and Payless..$50
You have to be quick Guys
This one is for Morris and Marcia Gets the Manual one
PostPosted: Sat Mar 19, 2005 12:33 pm
blaxland wreckers didnt have one :( so ill look in some penrith wreckers
PostPosted: Sat Mar 19, 2005 7:13 pm
is there any left at pick and payless
maybe i should try there :)
PostPosted: Sun Mar 20, 2005 6:56 am
Possibley.... I saw this one....undid it and left 8)
I'll be going back again some time this week again for some thing else :wink:
PostPosted: Sun Mar 20, 2005 4:49 pm
went to pick and payless tday all the pulsars were raided but there were 4 astras with there distributors all d4r83 except one which was a d1414 or sumthin
got the distributor and coil and cool 8mm red leads for $40 :)
i think cause i said it was a astra one i got it cheaper
mine was of a manual but was the d4r83 any 8ideas??? :?
PostPosted: Sun Mar 20, 2005 6:43 pm
Whether it's an 83 or 85 doesn't really matter, either will perform better than any old POS Lucas one. :wink:
PostPosted: Sun Mar 20, 2005 7:14 pm
ok cool thanks for the help
PostPosted: Mon Mar 21, 2005 5:51 pm
were does the vacume advance tube go as my old distibutor had no advance. also the wire near the advance with the condeser is that the same wire as the single on off my old distributor :? :?
cant wait to get it on :)
PostPosted: Mon Mar 21, 2005 6:41 pm
If the SU carby has a tiny connector on front of it put a hose on there, if not just leave it. If you have Weber or Dellorto, leave it- there's nowhere to connect.
"Performance 4s don't need this crap to make power.. eg Cooper S, Alfa & Fiat twin cams, etc."
It's an economy device, nothing more. When the pedal is to the metal, the vacuum advance does SFA. 8)
PostPosted: Mon Mar 21, 2005 7:00 pm
also is the wire near the advance with the condeser is that the same wire as the single one off my old distributor
PostPosted: Mon Mar 21, 2005 7:41 pm
That condenser is just a radio suppressor. Bin it. Not needed. 8)
PostPosted: Mon Mar 21, 2005 7:43 pm
so have nufin on that plugy thing next to the advance
PostPosted: Mon Mar 21, 2005 7:44 pm
True. It's just an earth point. Leave it... :lol:
PostPosted: Mon Mar 21, 2005 7:49 pm
ok this is started to make sence now but one last question how do you know when piston 1 is at top dead centre
my dad said take out a plug and shine a touch in but whats the best :) way
