It is currently Fri Jul 18, 2025 10:39 pm
Post new topic Reply to topic  [ 452 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 31  Next
PostPosted: Sat Oct 02, 2004 4:59 pm
Whitestriped63 wrote:
1LS and 2LS Brakes?
Not quite C/L?
L/R. left and right?
1 leading shoe (850) 2 leading shoe (the rest)
on C/L== on centre line (of hub)
L/R yes, left and right. The top holes are opposite hand (slightly) each side.
8)
PostPosted: Thu Oct 07, 2004 1:57 pm
miniVan wrote:
ok, well turns out that the $1100 setup from the local mini place is actually for standard single pot 8.4" discs (like the mokes) what a rip.. i can buy two mokes for that. they also rekon the civic setup will root up all of my geometry.. now i havent done geometry and trig since high school, but if i'm using the same drive flanges and end up with the same offset as my spaced drums.. i can not figure out how f'n possible this could even alter my suspension geometry let alone root it
Time to find another 'local mini place'..........He is pretty keen to sell you those moke brakes. If he was a decent machanic, it doesn't take much to work out just changing the disks is not going to change the geometry :roll:
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu Oct 07, 2004 2:05 pm
miniVan wrote:
anyone here in perth done a succesful conversion.. woulnt mind seeing it
I was planning on doing it, but I havn't gotten around to doing the paper work to see if the Transport people will let me... dont want anything like this to void my insurence, in case anything happens.
What mini place? The one out Armadale way / or the one in Bayswater?
Matt
PostPosted: Fri Oct 08, 2004 11:38 am
bayswater
i dont have a mechanic.. i just need somewhere to source parts locally when i'm in a hurry
and you dont have to be a rocket scientist to know that its not going to change geometry
does anyone here have any drive flanges lying around?
and some 25mm spacers?
PostPosted: Fri Oct 08, 2004 12:09 pm
Cheapest way to get spacers is find somebody with a lathe (truck repair shop, machine shop, toolroom, etc) and get them to slice a couple off some Mini S drums.
That way all the holes are in already, and they will run true. :wink:
Drive flanges are off any drum braked Mini. Just watch they are not grooved where the bearings sit (a common problem).
PostPosted: Sat Oct 09, 2004 4:55 pm
Doc,
Relieved a couple of 83-84 Preludes of there anchors this morning. Disc diameter is 229mm and roughly 49m thick. I am running 12*5 Superlights. Assuming i use a backing plate (say) 3.5mm thick and the disc is 49mm thick, what thickness spacer do I need?
Maybe you could post what the total calculation needs to be? Like if your backing plate is 3.5mm and your disc is 49mm your spacer needs to be ....... thick.
JC
PostPosted: Sat Oct 09, 2004 5:49 pm
Hi I've not done Prelude brakes, can you PM animal, he's got a handle on those. :wink:
PostPosted: Sat Oct 09, 2004 5:53 pm
Doc, is there any chance the spacer may not be required? I mean if there is enough clearance inside the wheel to not require it or is it spacing the wheel to give accurate track?
JC
PostPosted: Sat Oct 09, 2004 7:42 pm
if anyone has a cad drawingof a backing plate made of 8mm plate for 12inch discs (140mm caliper spacing ) can they please email a copy to me at [email protected]. thanks, ben. ill also look into getting a few sets made at tafe for free/ cheap
lookin for another clubby
PostPosted: Sat Oct 09, 2004 8:58 pm
As has been mentioned there is a problem with legality/responsibility and distrubuting these cad drawings.... plus anyone who has spend the time making acurate ones (mine has takes almost two solid weeks!!! to do it to a fanatical standard) probly wants to make a buck of them
G
--Insert legal disclaimer here--
PostPosted: Sun Oct 10, 2004 5:27 pm
G
I really can't see how you could be in trouble legally. Anybody who does the modification HAS to have it engineered. If your brakes fail you go and bust up your engineer... not the bloke you aquired the plans from. If you don't get it engineered then your a twit and you deserve to die.
I agree... if you've done a good job of the drawings you'd wanna get a couple of bob for them.
dewey
dwightgunning.com
PostPosted: Sun Oct 10, 2004 7:28 pm
Dewey, the problem here is- a lot of people DON'T go to the trouble of getting them engineered. Then (in theory) if the brakes `fail' and you hit Lord Muck and kill him, the guys who proposed the mods could be in deep doo-doo. :cry:
PostPosted: Sun Oct 10, 2004 8:15 pm
You have a better idea of thel details when bobtel sought legal advice and I've been through my thoughts on this before.
Don't call me 'Judge dewey'... because I'm not :)
When it boils down it shouldn't be that hard to whip up a decent CAD by yourself or just get out the angle grinder like Kev
dewey
dwightgunning.com
PostPosted: Sun Oct 10, 2004 9:17 pm
i've pms animal twice now and no reply
i just want to know what year accord did he get his vented rotors off
how many pots on a civic caliper and how many on the accord
i didnt realise you could use a prelude
PostPosted: Sun Oct 10, 2004 9:49 pm
My bad- I thought he meant Accord. :oops:
I don't think late Prelude (or late model Accords either) brakes will fit, they look too big....
but if they are 229mm they should work, with 12" or 13" wheels.
animal posted somewhere in this thread what year his Accord was, I think... :wink:
<edit> These Accord brakes are single pot just like Civics, but ventilated. 229mm dia.
Animal's piccies, Accords on the Mini.... swivel hubs & drive flanges are drum type..
He used 13x6 wheels.
Last edited by drmini in aust on Sun Oct 10, 2004 10:08 pm, edited 3 times in total.
Users browsing this forum: No registered users and 18 guests
