It is currently Sat Jul 19, 2025 6:45 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Mar 26, 2010 6:18 pm
I've been away for a bit over a week's holiday in Perth. Got back just yesterday.
I took the head off the Moke today. Cyl 2+3 were blown to the water jacket at the back of the head. The head has a 8-10 thou depression in the area of the blow. It's got really hot at some stage.
The block is dead flat, which is a relief.
I've dropped the head off at Hoppers Express for a cleanup, pressure test, crack test and a skim.
The bores are absolutely perfect, spotless and measure up at standard size which is pleasing. It should be up and running again soon. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Apr 03, 2010 4:53 pm
Job done, cooling perfectly. Sits between 80 and 90 degrees C with the fan cutting in and out like it should.
Seems to have a little more grunt now too, but that may just be my perception. :)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
