It is currently Sat Jul 19, 2025 6:59 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Mar 18, 2010 10:26 pm
poeee wrote:
That's a mod to the contour of the body though???
The valance panels are always rusty and you will need to replace it with a non-genuine panel. It is a pity that the non-genuine panel is two foot longer than the original but hey! What can you do. :lol:
You could get away with a slight modification but not a major one. As long as there is no other Minis parked nearby that they can look at.
PostPosted: Fri Mar 19, 2010 1:29 pm
I could fake some rust holes and they'll think it's just a normal Mini part just rusting away like the rest of the car.
PostPosted: Fri Mar 19, 2010 6:58 pm
I trust you're talking about the van here. Longer, more aerodynamic?
Moon discs and rear spats would certainly 'look' faster. Add a coat of matt black and she'd go down a storm on the salt.
Madmorrie
PostPosted: Fri Mar 19, 2010 7:26 pm
I know I have pics of a Mini Mania Salt Racer somewhere :twisted:
yer okay its a 1275..but I know you can get something from this
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
PostPosted: Fri Mar 19, 2010 8:14 pm
I did learn a couple of things from that.
Hmmm, a 6 speed box.
I wonder how much faster it would have been if they could make a 7 speed?
PostPosted: Fri Mar 19, 2010 8:20 pm
more gears = more weight + more rotating mass + more oil-pumping losses between the gears teeth = more loss of power
one over drive gear is enough,,,, "IF" you have the power to turn all that extra gear ratio,,, dont` see an 850 having enough power to turn a 3.4f/d ratio let alone an overdrive sorry :-)
PostPosted: Fri Mar 19, 2010 8:51 pm
So tell me. What would a race spec 998 engine get... in terms of HP. This wont be too far bellow in capacity.
PostPosted: Fri Mar 19, 2010 8:54 pm
Good race 998 = Well over 100HP at the crank.
PostPosted: Fri Mar 19, 2010 9:00 pm
100hp at the crank would get me to my target... surely...
PostPosted: Fri Mar 19, 2010 9:53 pm
Lionel Ayers & i helped set up a formula Junior donk for an old fella,,, his name escapes me atm,,, damn my brain just doesn`t work at the best of times these days,,, lucky we didn`t fit a heavy flywhjeel to the damn thing hey? :-) ,,, ah,,, er,,, i`ll remember his name in a minute,,, i`ll edit this later with his name
anyways,,, This "Old-flella" was harrasing me for ages to do his cyl head for him & i was sooo busy at the time (lifting my house up) that i decided i`d help,, butt,,, what i did was show Lionel what i "Normally" do to small bore heads to make them work,,, anyways, Lionel did a fantasic job & the engine dyno that it was run-up on showed 120 at the crank
now i firmly believe that this particular engine dyno was a bit,,, er,,, ah,,, i shall say """Light-on"'" (maybe not, butt i havn`t seen numbers like that on any small bore before) so it may not have been "exactly" 120hp,,, but still,,,, this particular formula junior has recently traveled the world chasing the formula junior race series winning just about everything it raced in
But hey,,, thay`re just small bores :-)
PostPosted: Fri Mar 19, 2010 10:45 pm
100mp/h is supposedly possible from an 850
PostPosted: Fri Mar 19, 2010 10:47 pm
Just seal up the roll cage & pump it full of NOS, & pipe it into the under-side of the manifold
they won`t notice
PostPosted: Sat Mar 20, 2010 9:56 am
The aerodynamics are probably the most important factor at high speed. When you're starting, it counts for nothing. I heard that the bugatti vayron needs 250hp to stay steady at 300km/h, but over 1000hp at 400km/h. As said earlier, doubling speed quadruples friction.
I've done dome work at uni with model solar cars, and found that about 2/3 of the power of one of these model solar cars at fulls speed is used on air friction. A petrol car will naturally have more drivetrain losses, but they're also a lot less aerodynamic - I think a standard roundnose mini has friction coefficient of about 0.45 - 0.48. Not to mention a squarenose...
The NT - adelaide solar cars can have coeffients as low as 0.1. But they need to be road legal, and adding the exterior rear-vision mirrors DOUBLES the friction coefficient.
PostPosted: Sat Mar 20, 2010 11:37 am
hence why they`re called "Bricks"
PostPosted: Sun Mar 21, 2010 11:21 pm
The last edition of MiniWorld that I saw on the shelf had an article where they spent a day in the MIRA wind tunnel... They said 0.58CD, and did a few tests to test how they could reduce drag and lift. Might be worth a look..? I'm guessing they've gone further than you can in the regs, but still... It was interesting.
