It is currently Fri Jul 18, 2025 7:09 pm
Post new topic Reply to topic  [ 452 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 31  Next
PostPosted: Tue Oct 19, 2004 10:54 pm
word to that Kev!!
PostPosted: Wed Oct 20, 2004 8:11 am
The 'original' S brakes dont even come close to the type of braking ability I have with 9" discs :shock: I want' to test them against some 8.4" Metro Turbo brakes though :D
PostPosted: Wed Oct 20, 2004 10:26 pm
I reckon the engineers wont like the amount ground of the caliper on the 7.9 conversion...
G
--Insert legal disclaimer here--
PostPosted: Wed Oct 20, 2004 10:52 pm
G
I think they are better under 12" wheels, then no mods to caliper or disc at all.
My City ones have a bit ground off, but it wasn't obvious. At least there's no fluid there, just metal.
Paint 'em, black or whatever floats your boat... 8)
PostPosted: Thu Oct 21, 2004 8:23 am
Any clues as to what's happening here? When I pulled the calipers off the Civic at the wreckers one disc came off easy peasy with the puller. The other is still there :evil:
As I cranked the puller up it appeared as though the disc was staying stationary and the shaft was being pushed in toward the engine. It reach a point where it would go no more. A BFH didn't do any good. Should I just forget that one and look for another? I picked this set as they had the least wear.
PostPosted: Thu Oct 21, 2004 8:46 am
This may sound silly but you did unscrew the 2 little screws that hold the disc on?
Also, I got the discs and calipers off a 82 prelude. Are these the same as on the civic? I know replacement discs are 231mm dia and 50mm wide. Any idea what thickness of caliper mouting plate is needed for these?(still 8mm)? I'll be using the 10" conversion.
PostPosted: Thu Oct 21, 2004 9:29 am
guys,
mini spares center australia (mini car clinic) has a set of discs and calipers that will go on standard hubs (need 12" wheels because of size of calipers) (come with custom backing plate)
has anyone heard of these or even better seen any in action?
i'll find the price out today and get back to you
PostPosted: Thu Oct 21, 2004 9:47 am
miniVan wrote:
guys,
i have seen a pic of these, BUT i think you will still need an engineer to certify these as there is no mention as to an engineers certificate in the advertisment.......
lookin for another clubby
PostPosted: Thu Oct 21, 2004 11:29 am
does anyone know about disks off an '88 civic? - all the talk here is about slightly earlier ones. I am getting a set in a roundabout kinda way and wonder if they'll do me any good
what about off a swift GTI?
PostPosted: Thu Oct 21, 2004 11:33 am
Wombat wrote:
Any clues as to what's happening here? When I pulled the calipers off the Civic at the wreckers one disc came off easy peasy with the puller. The other is still there .
David, my Civic discs came off very easily. No drama's. As suggested, those 2 small screws have to come out. Then the disc should slide straignt off, with no encouragement froma BFH. :wink:
PostPosted: Thu Oct 21, 2004 12:03 pm
Screws?? What screws?? No seriously I'm sure I took the screws out - a couple of weeks back now - been otherwise occupied!! But I'll go back and check when the Doc (not Kev) says I'm allowed to.
PostPosted: Thu Oct 21, 2004 12:16 pm
84-87 afaik, although i have callipers from an 82 civic on mine and rotors from an 84-87 civic. dunno bout swift discs, id say keep em in case ;)
PostPosted: Thu Oct 21, 2004 2:04 pm
miniVan wrote:
guys,
I think this was the Camira based kit? If so, Jan's Mutant used to have a set of these before the Mutant makeover. John (Jan's husband) said they weren't much good and they made the front wheels stick out further than regular 8.4" Mini disks.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Oct 21, 2004 7:54 pm
none of the numerous sets of brakes i have procured required any BFHing
i glanced over the brakes of a charade last time i was at pick and pay more, they looked pretty small..... thought about grabbing a set but i reckon i have enough honda ones to convert before i look elsewhere
Yeah kev, i reckon the 12 inch conversion is very engineer friendly, i suppose it depends on how thorough the engineer is, if i had to put my safety approval on them i certainly would like to know whats been taken of where, i reckon i would like to compare the caliper to an unmodified one.
G
PostPosted: Fri Oct 22, 2004 9:59 am
bloody hell,
mini car clinic want 2500 bux for those discs (no i didnt miss a decimal)... i'm flabbergasted.. haha (nicest choice of words i could use) thats more than they want for their brand new set of cooper s discs (just) and alot more than their reco set
anyway.. onto the hondas..
thats it i dun know what to say anymore... are all suppliers conmen?
Expert in training
