It is currently Fri Jul 18, 2025 3:53 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Thu Oct 30, 2008 8:04 pm
Here is a different pic of what has to be done with the hydro pipe. The kit is the standard kit unmodified for Hydro a few people have done it now it's not a very big issue just need to move the pipe about 100mm towards the edge of the car.
4efte powered Clubman
supercharged 998 race car
PostPosted: Fri Oct 31, 2008 10:14 am
Cheers Ben that picture shows what i mean alot better. its not a special seperate kit for the hydro works fine like this however i would definetly suggest some kind of mod to your suspension
Enjoy Chris ;)
PostPosted: Fri Oct 31, 2008 8:24 pm
Yes your car is what can happen when you have a stanard height hydro car and add a lot more power than it had before. I have seen a couple other hydro cars that show the same thing under acceleration nose up and squat the back down and they were only NA with a lot less power..
PostPosted: Fri Oct 31, 2008 8:53 pm
What type of mods and for what purpose?
I'm running Koni shocks at the front (from memory) and competition bump stops on the rear.
- Simon -
PostPosted: Fri Oct 31, 2008 9:12 pm
Ziegech wrote:
yeah it was pumped to stock height last time i got it pumped. i thought anything below stock was bad for the bags???
That is far too high for performance use, front wheels are pointing every which way.
Mine runs 2-3 fingers height at front, has done for 14 years.
Just let some fluid out.... :lol:
My bags are 1970/71 vintage. Has Pedders shocks on front and comp bumpstops at rear.
PostPosted: Sat Nov 01, 2008 12:41 pm
Ok well my ideal is the coil over or shockers at front and bump stops at the back but right now i cant afford it i will be lowering it next chance i get but i want to do it with a hydro pump to get it even and so i dont injure myself trying to release the pressure
Enjoy Chris ;)
PostPosted: Sat Nov 01, 2008 5:44 pm
No way you will hurt yourself letting fluid out, just use the back of the valve cap to push the stem in a little bit. Then just hose it away, it's mostly water... :lol:
PostPosted: Sun Nov 02, 2008 4:54 pm
That would be the only mod needed just to stop the nose from lifting
PostPosted: Sun Nov 09, 2008 10:29 am
I run comp bump stops on my standard hydro car and Ben's excellent kit works well.
I run front and rear as it give some protection if a displacer ever fails.
