It is currently Fri Jul 18, 2025 5:48 pm
Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Mon Mar 07, 2005 11:11 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
well i hate to say it but you both want to raise the bar a heap rob diamanti's ford blue clubby with the full leather interior 13" simmons turbo motor and all the other bits is the cleanest and the i honestly have to say it is one of the best mini's i have seen either in australia or in any of the mags it is great ........
i have gotten up close and personal with this car and i could not fault it
makka
PostPosted: Mon Mar 07, 2005 3:50 pm
heaps good! if you want a turbo one, midel can convert it for round 250.... or buy a turbo one brand new for 500 (depending on exchange)...
what is the formula for this killer engine build???
68matic: "i havent seen much head in my life "
PostPosted: Mon Mar 07, 2005 5:08 pm
Midel can convert an SU TO Blow-through Turbo Setup ?
Nice.....
Personally, if i had the cash, i'd go with the NEW one (Hopefully Ex-Burlen!)
Then again, still contemplating "Wet-Manifold" injection........
J
PostPosted: Mon Mar 07, 2005 5:37 pm
have you seen this james???
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 81839&rd=1
1974 Moke - 998cc
PostPosted: Mon Mar 07, 2005 5:48 pm
Oooooohh That Purty.....
I was thinking a Twin SU manifold myself.. but thats cool too !
Damn, the wheels are turning in the head again.....:?
J
PostPosted: Mon Mar 07, 2005 10:37 pm
that seems great... wonder what ECU he was planning on using....
Do you reckon kev could make something like that up???
PostPosted: Tue Mar 08, 2005 5:34 pm
looks nice eh!
endless supply of fuel to :D
immm just gunna nock around with a SU thou..mine is gunne be running pritty low boost untill POP,then it will be swapped over for a better motor :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Mar 08, 2005 5:41 pm
slightly off topic cause its not a mini, but maybe give you more ideas, like two tiny turbos, 1 for each inlet port? hah!
http://www.lateral-g.org/sandlin/
PostPosted: Tue Mar 08, 2005 5:44 pm
wouldnt the t 550cc injectors he had with it be alittle over the top for a mini?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Mar 08, 2005 5:50 pm
that would take so much setting up to get them all running rite :D
-have we got an me says we need to get together and make an OFFICIAL AUSTRALIAN turbo minis page!
full of tips,HP read outs,photos and all that hoo har :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Mar 08, 2005 6:08 pm
just a thort,that throttle body would have to be pulled apart and have O rings put thru it to be sealed up B4 a turbo could do its thing eh..?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Mar 08, 2005 6:39 pm
Why ? All it will leak is air ........ and not very much at that !
Should already have labyrinth type seals on the shafts anyway...
J
PostPosted: Tue Mar 08, 2005 7:25 pm
whats the cost of sealing up a su to run with a blow through turbo setup?
PostPosted: Tue Mar 08, 2005 8:50 pm
you need the bigger injectors because each inlet is feeding 2 cylinders... I was talking to the guy that is going to make up my turbo manifolds today and he was thinking bout options for efi...
he thought that 4 smaller injectors, two in each inlet, would be ideal as you could rig it so that at idle and low throttle settings only run 2 of them and then let the other two kick in at a set stage to give more fuel...
PostPosted: Tue Mar 08, 2005 9:12 pm
Many people have tried..just as many have failed, even the factory couldn't get it right for a power tuned car..
