It is currently Thu Jun 26, 2025 5:21 pm
Post new topic Reply to topic  [ 116 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
PostPosted: Thu Jun 14, 2007 5:09 pm
The BMW engine is a motorcycle engine and the RTA would not allow it to be registered with a motorcycle engine. 8)
The BMW MINI does not have a BMW engine. The first model used a Chrysler motor and the current model uses a Peugeot motor. :wink:
PostPosted: Thu Jun 14, 2007 9:15 pm
I always loved the irony of the BINI having a Chrysler engine... Given that the joint venture was organized just before the DaimlerChrysler "Merger of Equals". It was almost like a Holden with a Ford engine. :lol:
PostPosted: Fri Jun 15, 2007 6:34 pm
Morris 1100,,, i`m pretty sure the Dpt of Tpt would allow a motorbike engine in a mini, as long as it is engineered well & has a reverse gear of some sort
& The first of the New BMW MINIs did have a chrysler engine but the new version which is now turbo charged has an all BMW engine,,, it`s just that Peugeot uses the same donk in one of their cars & was very quick to point it out to the media so as to make it sound like it was the other way around
but anyways, just thought i`d let you know the facts
PostPosted: Fri Jun 15, 2007 7:25 pm
The RTA in NSW would probably baulk at the swap due to the emissions rules on engine swaps. But if you stamped your old engine number on the BMW block I doubt if they would ever know!
TheMiniMan wrote:
.. but the new version which is now turbo charged has an all BMW engine,,, it`s just that Peugeot uses the same donk in one of their cars & was very quick to point it out to the media so as to make it sound like it was the other way around
Ta, I was told it was the other way around. :wink:
PostPosted: Tue Jun 19, 2007 1:09 pm
The BMW bike engine turns the opposite direction & then has an "Idler" gear to change directions back to the right way before driving the gearbox.
I don`t believe it would be worth trying to fit the whole BMW bike engine onto a mini gearbox cause it`s such a right mess of an adaption that the time /effort & money & the shear egineering of it is just way way too much to even concider
i have looked at the whole lot & it`s just not an easy application at all
But the bike engine "Idea" like a Suzi hyabusa or a Yammy R1 etc into a mini subframe is quite a neat package, mine is sweet & the reverse gear part is easy with just the fitment of a starter motor onto a ring gear on the the diff,,, or sproket on the starter into the chain. easy-peasy :-)
& i can`t see a problem with emissions for Dpt of Tpt approval as nearly all the late bike engines that are currently imported from Japan have emissions stuff all over them, so it shouldn`t be an issue. But i`m yet to check with my people,,, it`s not "what" you know, but "Who" :-)
PostPosted: Tue Jun 19, 2007 7:44 pm
I'm aware the K1100 rotates backwards- but why not change direction?
We did it years ago with a Fiat 850 sport motor (anti-clockwise rotation) we had put on a 600 box- as the car then had 4 reverse gears and 1 forward! :lol:
So we turned pistons around, and swapped the cam, oil pump, starter, dizzy etc from the 600.
Can't you just turn the pistons around, blah blah? not rocket science.... :wink:
PostPosted: Wed Jun 20, 2007 2:06 pm
Doc, the Bimmer bike engine lays down sideways, that`s the main problem with trying to convert it to a mini box, plus the fact that the massive "Idler" gear is situated in quite a funny weired spot & then you`d need some wild adaptor plates & AHHHgggrrr,,, it`s just way too much to bother when all you really need is the cyl head from it ,,,& it`s soooo dam easy to bolt that onto a mini donk. If you took a look at the Bimmer donk you`d see what i mean.
& we do reverse the direction of rotation of the cams in the Bimmer cyl head when fitting it onto the mini donk anyways, they`re concentric cams so it`s all good :-) change the plug leads around & start the car, easy-peasy :-)
PostPosted: Wed Jun 20, 2007 3:33 pm
am i thinking right in the fact that the bike is rated 110hp, you'll get much more out of using the head on a mini block (with more cc's) then if you just used the bike assem?
on a std 1275, with a bmw 16v head with efi, 120hp should be pretty easy to reach NA
PostPosted: Sat Jun 23, 2007 6:34 am
yes is the answer - my 8v twin cam 1293cc made 107bhp on bone stock 8v components, my 1380 16v made 163 bhp on ported head/ sprint cams - 34mm throttle bodies (160ish is the limit for 34mm bodies) - its now wearing 38mm K1200 bodies and will hit the dyno next week.
JK
PostPosted: Mon Jun 25, 2007 9:42 pm
All the pulleys have arrived from Japan, (Finally) all shiney & new, :-) we have most of the kit all programed into the CNC machine now, just wating to get some more time on the mini cam pulley boss & the upper cyl head blanking end plate & we`re ready to do runs on all the bits.
The old broken down CNC machine is also now up & running again so we are all ahead steam
Just thought i`d give you all an up-date
:-) &yes i am very happy indeed :-)
PostPosted: Mon Jun 25, 2007 10:23 pm
Doc I believe the old Lightburn Zeta did the same thing, you could start the engine in reverse and have 4 reverse & 1 forward gear!
Noli Illegitimi Carborundum
PostPosted: Mon Jun 25, 2007 11:03 pm
I think the Zeta was started in reverse direction to go backwards- it had no reverse gear. :wink:
I seem to remember Goggomobil too? My mate had one . "No, not the Dart..." :lol:
PostPosted: Tue Jun 26, 2007 12:45 am
i congratulate you for dreaming this up and deciding to make kits for the rest of us to enjoy,
will you be doing drive in drive out conversions? as i think this would be far too complicated for mere mortals to do themselves..
PostPosted: Tue Jun 26, 2007 11:48 am
Spaceboy i`m doing just that for 2 customers right now, one is going into a really nice looking moke with turbo injection etc & hope Watto likes it enough to do a write up & photo shoot for the mini experience magazine, so i spose the answer is yeah, allready doin it :-)
PostPosted: Tue Jun 26, 2007 12:00 pm
& just because i like you all soooooo much i thought i`d give you all a sneak preview of the moke that is in the process of being "Turbo injected Bimmer Twinky-ised"
