It is currently Mon Jun 23, 2025 12:44 am
PostPosted: Wed Oct 20, 2004 8:34 am
Would anybody know the widest tyres that I could fit to the rover 12 x 4.5 rims? I currently have 145's on them now but would like to put on 165's.
Also any recommendations on the type of brand/model of tyre?
Thanks
PostPosted: Wed Oct 20, 2004 10:12 am
Thanks
falken 165s will fit aswell as yoko 165s ;) they are ya only 2 choices afaik
lookin for another clubby
PostPosted: Wed Oct 20, 2004 11:05 am
What you have is 145/70R12. You want 165/60R12 as a replacement to maintain roughly the same rolling diameter.
Apparently 155/70R12 are available, but may cause clearance problems due to the increased diameter. I would stick with 165/60R12. 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Oct 20, 2004 11:15 am
thanks guys :P :P
Me thinks I will go with the Yokohama A539's 165/60R12 they seem to be spoken about fairly well
PostPosted: Tue Oct 26, 2004 9:08 am
bnicho wrote:
What you have is 145/70R12. You want 165/60R12 as a replacement to maintain roughly the same rolling diameter. 8)
Ok one more stupid question, the main reason for wanting to change the tyres is for mainly asthetic reasons (although the old ones are starting to crack a little also). Will the 165's give the wheels a wider look than the 145's or will they just push upwards due to the width of the rims..? i hope that make sense :?
PostPosted: Tue Oct 26, 2004 9:16 am
No, they won't "push upwards". The sidewall height is pretty similar.
Yes, they will look wider on the car. 8)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Oct 26, 2004 9:56 am
thanks again!
