It is currently Mon Jun 23, 2025 3:45 pm
PostPosted: Thu Oct 28, 2004 7:45 am
Hi all,
Is it possible (and I'm fully prepared for it not to be) to replace the K series doors* on my van (which are rooted) with any others? Can I use internal hinge MK III doors? There was a bloke selling a pair of NOS doors, but he wanted NZ$500 each... The van's probably going to need certification for other stuff anyway. TIA.
* K-series are external hinge / lift-up handle / quarterlights / burstproof latch
PostPosted: Thu Oct 28, 2004 9:00 am
Why you call them K series doors? Is that Kiwi thing???
To us they are plain old Oz Clubman doors!
UK MkIII+ doors will not fit on an Oz car without major surgery. The are different in every dimension - taller, wider and a different shape top and bottom. To fit them you would have to change the inner and outer A panels (between front guards and doors) for MkIII ones. You would also have to modify the B pillars, modify the sills and modify the panel above the door and below the roof gutter. Not impossible, but not easy all the same.
Hope this helps.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Oct 28, 2004 1:33 pm
I've pondered the idea of grafting a set of UK internal hinges into an Oz mini somehow. Without having looked real hard at it, I reckon that it might be do-able. Anynoe got any clues?
Who's MadMax?
PostPosted: Thu Oct 28, 2004 1:46 pm
hmmmmm....I don't think that would be legal! Imagine if you were in a crash.....they might fall off or something.
I think that might even need an engineers approval...?!?
PostPosted: Thu Oct 28, 2004 2:32 pm
Hey, if the people at the autosalon car shows can fit suicide doors and scissor doors, then internal hinges on a mini are possible. I know a few ways it couls be done. Some require a lot of body work, and others only need a welder.
PostPosted: Thu Oct 28, 2004 8:14 pm
bnicho wrote:
Why you call them K series doors? ......... .
coz thewy were fitted to a mini k :P
lookin for another clubby
PostPosted: Thu Oct 28, 2004 8:35 pm
They were fitted to SOME Mini- K's (and MK2 S's). Only the last. My 3/70 car has the earlier style windups with `Real' Mini door handles.. :P
PostPosted: Thu Oct 28, 2004 9:33 pm
ok sorry that i can't help with much detail
but i know that u can fit the UK internal hinges into a aus mini
i have seen it done
one of my mates dad's is building a race mini and it has internal hinges
hasn't finished it off so he hasn't bothered making the doors line up properly but he just got a panel beater to fit them needed the hinges and the A or B pillar (which ever is infront of the door hinge)
sorry can't tell ya much more
PostPosted: Thu Oct 28, 2004 9:56 pm
Yeah, I reckon for somone what knows what they're doing it wouldn't be too hard. If it was done right there shouldn't be any probs with it - prolly need an ginger beer's certificate though.
Who's MadMax?
PostPosted: Thu Oct 28, 2004 10:02 pm
Aren't they just standard clubman doors? Or is it some retarded merging of the two types?
I had a look at mine (lift up latches on a mini K) on the weekend and everything looks good up the top of the door. I think I will get some aerosol fisholine oil and nail the bottom where the water will be sitting.
dewey
dwightgunning.com
PostPosted: Thu Oct 28, 2004 10:10 pm
Late Mini K or 1275S doors are Oz Clubbie doors.
re the internal hinges- if you look at the 2 cars side by side, it's serious crap to change it. The whole A pillar is different internally.
Also, the internal ones are allegedly less strong- :roll:
PostPosted: Thu Oct 28, 2004 10:24 pm
Gotta admit, I haven't had the opportunity to look at the internal hinge set up in the flesh... just piccies in the UK mags. Seemed like a good idea though.
Who's MadMax?
PostPosted: Fri Oct 29, 2004 1:02 pm
My 11/1970 Mini K van stil has the earlier tyupe handes too. I have seen one 3/71 van with the clubby doors. So my van may have been one of the last with old type doors!
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri Oct 29, 2004 4:39 pm
My van, a 1/70 has the old doors, and a magic wand. The Mini K I used to own, a 8/70, which was ex PMG was the same with the old doors and magic wand.
