It is currently Tue Jul 01, 2025 10:04 am
PostPosted: Sun Jan 04, 2009 9:29 am
Hi All,
Does anybody know the bleed sequence for brakes with the late type master cylinder.
Thanks
PostPosted: Sun Jan 04, 2009 1:49 pm
I went through hell recently bleeding a `78 tandem one. :x
I have since been told that one trick is to bleed LR & LF together, then repeat for RR & RF.
PostPosted: Sun Jan 04, 2009 3:44 pm
yeah,,, just bleed "A" front & "A" rear at the same time on the usual "Aust" Front/rear type tandem brake systems
but the UK & Jap type diagonal systems i expect will need "A" right & "A" left open at the same time,,, at a guess
PostPosted: Sun Jan 04, 2009 7:36 pm
Hmm Its a 93 Mk 3 Jap shell with japaneese master. I have bench bled the master now and it seems fine out of the car but once installed back in the car i cant get fluid through the top output
I have a gut feeling that the brake pedal is different and not allowing enough travel ( the pedal box is from a early system)
Its not easy to find much info on theese later systems, it seems i may have to try and find a jap pedal box.
Does anyone have any knowledge on theese systems and confirm or deny my theory
PostPosted: Mon Jan 05, 2009 5:04 pm
The jap ones generally have a vacuum booster attached to the master cylinder is this the case with yours? and the cylinder mounts horizontily and uses a bellcrank assembly to operate it. Should be able to use the old pedal but will need the jap bell crank
4efte powered Clubman
supercharged 998 race car
Users browsing this forum: No registered users and 30 guests
