It is currently Sat Jul 19, 2025 6:10 am
 Post subject: Pulsar Dizzy
PostPosted: Wed May 06, 2009 7:16 pm
Ok got my Pulsar Dizzy and modified it as the Doc and GR says.
The posts for the weights had a bit of rust making them stiff to
swivel so it was a good thing I redid the distributor.
It is a D4R83 and has 4 springs.
Some have taken out the inner springs, some have
said leave them in and some has taken out just one.
So what do you think I should do for a standard 1100?
 Post subject: Re: Pulsar Dizzy
PostPosted: Wed May 06, 2009 10:04 pm
I'd take out one of the 2 light springs to start with, for a stock motor. Note some dizzys have these inside, and some outside.
For a modded 1098 with cam etc, take both light ones out.
You can try removing both with a stock motor, but if it pings under acceleration, put one back in.
PostPosted: Thu May 07, 2009 6:22 am
Thanks Docjavascript:emoticon(':)')
