It is currently Thu Aug 14, 2025 12:56 am
 Post subject: Over bored 1275
PostPosted: Thu Aug 15, 2013 8:35 pm
Hi,
I got given a 1275 (1100s) block that has been over bored to 72.8mm.
Other than a boat anchor... what can I do with it??
? Bigger bore??
? Sleeve it??
Or is it really throw away....
Thanks
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu Aug 15, 2013 9:32 pm
it's fine - 72.8mm is an odd size, but is .008" under 73mm which is a common size, making a 1360
oops, hang on....
it's a boat anchor, give me a few beers and I'll take it away for you ;)
PostPosted: Fri Aug 16, 2013 8:47 am
You can go to 73.5mm (1380cc), [then 74mm (1400) if the block was offset bored].
Don't toss it yet... :lol:
PostPosted: Fri Aug 16, 2013 2:29 pm
Do you have anything to go with it other than the block?
I'm assuming you have other parts to build it up..
If not sell it.
