It is currently Sat Jul 19, 2025 10:13 am
 Post subject: bike engine into mini
PostPosted: Thu Jun 16, 2016 9:02 pm
hi all I'm in the process of modifying a Leyland mini and was wanting to no has anyone put a bike engine into a mini before . I'm not worried if I can register it or not just building the mini for fun thanx a lot .
PostPosted: Thu Jun 16, 2016 9:56 pm
Z cars in the UK have done heaps and they used to sell kits to do it but unfortunately they went belly up..
Sent from my SM-G900I using Tapatalk
PostPosted: Thu Jun 16, 2016 10:02 pm
There are lots if you look.. FWD..RWD . Multi speed sequential gearboxes are an advantage ... but not many bikes have reverse ..but there are options.
Cheers, Ian
PostPosted: Fri Jun 17, 2016 9:30 am
Depends on your budget.
http://www.vetech.co.uk/hayabusa/
Nick
PostPosted: Fri Jun 17, 2016 10:05 am
According to the mini magazine I was reading lately Z Cars is being revived by a Z cars owner and the original owner.
Roads need more corners
PostPosted: Fri Jun 17, 2016 11:06 am
Hey there Mini09,
I was looking into this a while back, as an option. still might do it one day :lol:
Both these kits use the Yamaha R1 (998cc) engine from the late 1999 -> Early 2003, after this the motor changes it size and doesn't fit under the bonnet. Both kits advise adding disc brake system as you are putting a 140-160 hp engine in the place of one giving 37 hp.
Try this kit, come with new sub-frame (advantage is a mechanical reverse driven from bike engine via special box) bike engine faces rearwards, carbs to the front, requires plumbing radiator to the other side.
http://www.pro-motive.co.uk
Try this kit as it has no or little modification to mini sub-frame, the kit bolt on bolt off (reverse is optional via a converted electric starter motor) bike engine faces forwards exhaust forward, allowing use of existing radiator.
http://www.lynxae.co.uk
Z-Cars is supposed to be getting back up and running but this has yet to be seen.
You could also try making your own Aussie custom sub-frame like the V-Tec and Suzmini guys!
Hope this helps.
Maelgwn No Mini Yet :(
PostPosted: Fri Jun 17, 2016 8:18 pm
Awesome thanks guys between the uncle and myself we have 12 minis 4 round nose the rest leyland. 1 has a turno starlet engine in it other has a swift engine. Looking at the 1275 block and bmw bike head for another .
PostPosted: Fri Jun 17, 2016 10:40 pm
There's one for sale on gumtree with an r1 and it's registered
PostPosted: Sat Jun 18, 2016 11:28 am
Hey Mini09
So that's why I can't find any mini's you have hogged them all :lol:
PostPosted: Mon Jun 20, 2016 6:40 am
Vetech are pleased to announce that the price for the Vetech Hayabusa engine conversion kit base unit will start from £11,600 + VAT for the base unit. A donor Suzuki engine needs to be sourced by the customer (left-over engine housings and components can be re-sold after conversion).
Holy ****** moley!! :shock: :shock: :shock:
Just what the fook do you get for GBP12k+?? And you still have to source a donor engine!! :shock: :shock: :shock:
PostPosted: Mon Jun 20, 2016 7:15 am
They do seem to have taken the most expensive approach to doing this - they have designed a new set of engine casings that will accept most of the Hayabusa components, but incorporate a diff, reverse gear, etc along with all of the elements needed to package it up as a replacement for the A-series.
Even once you have sourced your donor engine, and paid for the kit then you will still need to do a full rebuild of the motor to replace the engine casings.
PostPosted: Mon Jun 20, 2016 9:16 am
But it does look nice, I was watching it for a while, then saw the price. maybe if I won the lotto, but then it would probs be a superfastminis.com kit.
Nick
PostPosted: Mon Jun 20, 2016 6:58 pm
hahaah nah havnt hogged them all just a few lol
