It is currently Sat Jul 19, 2025 10:49 am
PostPosted: Wed Jun 22, 2016 8:53 pm
Hi I was wondering if you could modify non hardy spicer gearbox diff covers to fit the Hardie Spicer yokes
I recall that some of the non cooper S covers where a solid casting which may have been from a OZ gearbox and therefore there is enough material to machine out.
Has any one done this.
Out of stock at mini spares and $$$ for what they are
Ta
Kiwiinwgtn
PostPosted: Wed Jun 22, 2016 9:10 pm
Online
The one on the right here is thicker around the oil seal and can apparently be opened up for the Hardy Spicer couplings
PostPosted: Wed Jun 22, 2016 9:46 pm
Kiwi,
The thick Oz ones machine out fine, but the S bushes are exxy (S tax). Send me a pm if you want a couple of covers, machined or not.
PostPosted: Thu Jun 23, 2016 12:27 pm
can someone remind me why the one on the right has the extra ear on it - I think I knew once but I've forgotten...
PostPosted: Thu Jun 23, 2016 12:31 pm
Online
Keeps the detent ball and spring in on rod change boxes
PostPosted: Thu Jun 23, 2016 6:01 pm
Kiwi,
Thanks Kevin. I am sure I have a pair somewhere and some automatic side covers I can rob the bushes from.
I will get in touch if i get stuck.
Kiwiinwgtn
PostPosted: Thu Jun 23, 2016 7:34 pm
Just ventured out into the garage.
why cant i simply turn down the shaft of the yoke. its only 3mm larger than a non S one
I can mark it with a file so it should turn down ok
what am i missing here
PostPosted: Thu Jun 23, 2016 7:42 pm
All the torque is transmitted through there, if you turn it down 1/8" on diameter you are weakening it severely.
The splines are bigger than on lesser Minis, that is why the outside diameter is increased.
re the bushes- they wear, usually need replacement on a proper gearbox rebuild. If a sloppy fit, the seals leak sooner.
I would fit new bushes, bugger the expense. :)
Years ago there were Hardy Spicer style drive flanges sold to bolt onto rubber U/J output shafts. Dunno who made them, but I have seen several sets.
PostPosted: Thu Jun 23, 2016 7:47 pm
the bushes are another out of stock item.
So if i turn out the standard ones will an S seal fit into a non S side cover or do i need a special seal.
PostPosted: Thu Jun 23, 2016 8:43 pm
Both the bush and seal housing bores are enlarged by 0.125" diameter. Look like a S cover when done. :)
S bushes are available, try Karcraft, Minisport Oz or Classic Motoring. I just bought 2.
Edit need to bore bush to size after fitting. They are about 0.007" undersize.
PostPosted: Fri Jun 24, 2016 7:18 pm
i have the conversion seals in stock if you just sort the bush part
i also have the std seals
& the "s" seals
& lots of "s" side covers
& millions of std side covers
PostPosted: Sat Jun 25, 2016 8:39 pm
kiwiinwgtn wrote:
Kiwi,
Kiwiinwgtn
If you have the automatic gearbox output covers for the diff, you don't need to rob the bushes from them - you have everything already to fit Hardy-Spicer universals as they used them too. Or have I missed something?
Bill
PostPosted: Sat Jun 25, 2016 8:54 pm
I'd love to see this kit as it sounds like what I've been thinking about making...
PostPosted: Sat Jun 25, 2016 10:09 pm
It was back in the 70s, John Smidt would probably remember them.
(Edit) may have been KG Engineering?
Last edited by drmini in aust on Sun Jun 26, 2016 9:14 am, edited 1 time in total.
PostPosted: Sun Jun 26, 2016 8:47 am
Online
Bill B wrote:
kiwiinwgtn wrote:
Kiwi,
Kiwiinwgtn
Bill
Bill, the automatic ones are completely different...
Users browsing this forum: awdmoke and 108 guests
