It is currently Wed Jun 25, 2025 5:48 pm
Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Sat Jul 09, 2016 5:47 pm
Try this thread. viewtopic.php?t=92273
PostPosted: Sat Jul 09, 2016 5:54 pm
Do a ring around of the mini businesses viewtopic.php?t=80096 or post in the wanted section.
PostPosted: Sat Jul 09, 2016 6:09 pm
Brilliant thanks I'll make some calls in the morning I have just tried and failed to remove the door handle
1968 Morris Mini Cooper S
PostPosted: Sat Jul 09, 2016 8:13 pm
Is the car the original colour or is it slightly lighter , and is it a 68 ?
PostPosted: Sat Jul 09, 2016 8:26 pm
The register says sold Feb 69.
PostPosted: Sun Jul 10, 2016 7:35 am
oldblade wrote:
O the joy of owning an old mini the door handle just fell off and it was locked stuck at a shopping centre waiting for the NRMA
Tip: if u are ever locked out of a mini, usually banging in the quarter Windows enough opens the latch.
Nice looking car. As you replace items don't throw anything out. Original parts are getting very hard to find. Eg heater, radiator.
PostPosted: Sun Jul 10, 2016 8:42 am
Thanks the quarter window wouldn't open all day the rubbers have been replaced so that helps with Security
PostPosted: Sun Jul 24, 2016 10:51 am
Welcome oldblade...
Your blog showed enough gunk in the cooling system for me to be concerned about your engine block as well...change or flush out the radiator by all means...but maybe the car hasn't been run all that much in that past few years...a good hot flush may be in order (if there is such a thing!! :-)
another little thing is the head bypass hose...you removed a soft "temporary" (convoluted) type...and I suppose you replaced with a similar one...ideally, a more solid straight piece should be fitted (a job for when you next lift the head)
Have fun...
PostPosted: Sun Jul 24, 2016 11:14 am
9YaTaH wrote:
Welcome oldblade...
Have fun...
Thanks mate I ended up replacing the water pump, the Bypass hose with a solid one, The radiator, Thermostat and Housing and gave everything a good flush
Also gave it a good tune spark plugs leads coil pack battery and earth lead.
Been driving it all week and :lol: :lol: :lol: :lol: :lol: all-round
I have also bought the Gunson carbalancer and Gunson ColorTune just brilliant though all it did was confirm I had everything very close it's now perfect
PostPosted: Sun Jul 24, 2016 11:15 am
Updating with pics I have put elsewhere on the forum
Here are a couple of pics and vids ImageImageImageImageImageImagehttps://vimeo.com/174186025Image
and after it's bath
PostPosted: Sun Jul 24, 2016 2:41 pm
oldblade wrote:
Image[img]
Just a new chrome strip along the passengers side and she will look even prettier 8)
PostPosted: Mon Jul 25, 2016 9:59 pm
winabbey wrote:
Great looking car there oldblade. Looks like one you can do a bit of work on whilst still enjoying it to drive.
What are the giveaways that it might be ex-Police?
I don't really know but have been told by different people who know mini's that a few things stand out
- holes for the sun visors
- the carbs and manifolds
- something else i can't remember :roll:
PostPosted: Tue Jul 26, 2016 8:38 pm
also a couple of other little items today
- seat brackets
- stuck my head under the dash and found the mounting holes for the police radio just like the one at shannons
I am just curious the fact that the possibility i am driving an ex cop car kind of disturbs me as it tells me its been abused since the day it was first registered
PostPosted: Tue Jul 26, 2016 8:56 pm
Here are a few pics of the seat adjuster
The holes for the sun visor
The manifold and carb
And the bolt holes under the dash
Hope someone has some details note I am s novice but as they say curiosity got the cat and I'm the cat
PostPosted: Tue Jul 26, 2016 9:07 pm
I thought that also when I discovered my car was ex-NSW Police (see this thread - viewtopic.php?f=2&t=83696). But I now know they were well looked after by those who drove them. They were sold at auction after 30,000 miles so were usually only a couple of months old. If the body is straight on your car then any other wear and tear on suspension, steering, engine and transmission is easily fixed by replacement parts. Use by Police is not an issue. It's subsequent owners I'd be more concerned with.
The only signs that your car saw NSW Police service would be the holes for the mesh sunscreen, possibly holes for the steel sump guard, possibly reversing lights and almost certainly two holes in the front edge of the front parcel shelf rail on the passenger side where the Police ID plate was fixed. Also holes in the flitch panel under the power brake booster where a siren may have been located.
All Mark 1 and most Mark 2 Cooper S's used by Police were stock standard showroom models from a mechanical viewpoint. It wasn't until September 1970 that the modified engine with 1 1/2" SU's, rally camshaft, etc. was introduced. Two-way radios (AWA 25M) weren't fitted until late 1970 so those holes are probably from a standard radio fitted by a previous owner. Seat brackets were also standard.
If you can show it came with the current paint then I doubt it's ex NSW Police as all their cars were monotone (i.e. roof same colour as body) to my knowledge. This was done intentionally so they looked like a normal Mini to the motoring public.
If you want to chat further feel free to drop me a PM and I'll give you my mobile number. Between us we should be able to determine if it's ex-NSW Police or not.
