It is currently Sat Jul 26, 2025 11:42 am
PostPosted: Fri Sep 02, 2016 11:13 am
Just wanting to know how to tell the difference between hydrolastic and rubber cone upper control arms?
Thanks,
Steve
PostPosted: Fri Sep 02, 2016 12:19 pm
try a 3/8 bolt through the horizontal hole. If it fits it is dry, if hole too small it is definitely hydro.
PostPosted: Fri Sep 02, 2016 12:25 pm
Thanks for that :-)
PostPosted: Fri Sep 02, 2016 3:54 pm
Another difference is the distance between the pivot shaft bore and the centre of the strut ball socket centre. The hydro arm distance is 1/8" longer than a dry arm.
IE: the dry strut is 1/8"closer to the pivot shaft.
If you use a hydro arm with dry suspension it makes the front suspension a little stiffer.
RonR
Edit: Changed shorter to longer and hydro to dry.
I realised my error when I woke at about 3am this morning.
I am claiming a senior moment/case of brain fade or any other excuse you are prepared to accept.
68 build Mk1 Cooper S
PostPosted: Fri Sep 02, 2016 6:51 pm
Wouldn't it be softer with the higher leverage?
PostPosted: Fri Sep 02, 2016 7:06 pm
Thanks,
Steve
There is a bit of info here. http://www.minispares.com/article/MiniT ... suspension and http://www.mokeforum.com.au/index.php?topic=7678.0 ImageImage
PostPosted: Sat Sep 03, 2016 7:12 am
awesome, they were definately hydro ones then :-)
PostPosted: Sat Sep 03, 2016 9:53 am
miniron,,, the hydro knuckle hole is further away from the pivot pin
the dry knuckle hole is closer to the pivot pin
PostPosted: Sat Sep 03, 2016 10:49 am
Miniman,
See my edit.
I am suitable chastened.
RonR
PostPosted: Sat Sep 03, 2016 11:22 am
Would a dry arm on hydro system make it softer or stiffer.
PostPosted: Sat Sep 03, 2016 11:26 am
Softer, as the wheel has a greater moment arm to work with to the displacer.
Users browsing this forum: Bing [Bot] and 92 guests
