It is currently Sun Jul 27, 2025 11:06 pm
 Post subject: Twin SU setup numbers
PostPosted: Sun Sep 11, 2016 12:48 pm
What would a twin su setup with numbers AUD 679 be off
1970 MK2 Cooper S
PostPosted: Sun Sep 11, 2016 1:00 pm
http://sucarb.co.uk/hs4-carburettor-for ... matic.html
PostPosted: Sun Sep 11, 2016 4:29 pm
Yes thats for a single carb application
But what about a twin setup
1970 MK2 Cooper S
PostPosted: Sun Sep 11, 2016 4:59 pm
I'd guess that one of them is an AUD 679 from a mini and the other carb is from something else. Not a problem running two different ID carbs, as long as all the parts are the same.
Twin SU kits normally had L and R
PostPosted: Sun Sep 11, 2016 5:05 pm
That's the only reference to AUD 679 on the main SU website - a single HS4. Google seems to show it's a single carb as well.
Do both carbys in the set have ID tags? They should be marked with the same ID number and then L or R. If there's no L or R then it's for a single carby application. Maybe it's a twin set made from two single carbys?
Edit: timmy201 beat me to it. :|
PostPosted: Sun Sep 11, 2016 5:09 pm
Here are the numbers for the "Special Tuning" HS4 carbs. Not sure what spec the Aussie police cars had Winabbey?
AUD 224 L & R
AUD 640 L & R
AUD 709 L & R
http://www.somerfordmini.co.uk/eshop/in ... age&id=170
PostPosted: Sun Sep 11, 2016 6:25 pm
Someone get the SU book out :idea:
PostPosted: Sun Sep 11, 2016 6:27 pm
AUD 488
The spec was put together by Sydney-sider Bill Bressington (Fabre, SU Midel) especially for SPO41 cars. AUD 488 is not listed in the SU catalogue or on their website but I managed to get a copy of the spec sheet from their archive. It's headed NSW POLICE.
PostPosted: Mon Sep 12, 2016 6:10 am
the manifold has 12G2463 stamped on it
And the carb are left and right
1970 MK2 Cooper S
PostPosted: Mon Sep 12, 2016 7:21 am
and you live by the sea :!: :(
PostPosted: Mon Sep 12, 2016 7:58 am
The manifold number seems to be for a factory twin HS2 manifold, although they were able to be modified to take the HS4 pair.
http://www.minispares.com/catalogues/cl ... spx?1~7~60
Just because they are left and right it doesn't necessarily mean they are a pair. The left one might come from a mini and the right from a Morris 1100 or Marina or anything else.
Just remember the spec tag only refers to how the carb left the SU factory (needle, spring, etc) so if they have been changed since then the tag is no longer relevant. As long as the pair are the same spec they should be ok.
PostPosted: Mon Sep 12, 2016 8:20 am
these are not mine
just a photo sent to me
they claim the have bought a heap of police mini stuff
just trying to identify if in fact they are
1970 MK2 Cooper S
PostPosted: Mon Sep 12, 2016 8:42 am
The police manifold is AEG573 and modified as per this post for police use.
viewtopic.php?f=2&t=91444&hilit=Police+hs4
Carbs should have the CCV hoses as per this thread
viewtopic.php?f=2&t=92945&hilit=Police+hs4
PostPosted: Mon Sep 12, 2016 10:05 am
GundyGuy wrote:
these are not mine
No, sorry, they are not off an SPO41 NSW Police Mini. :cry:
Users browsing this forum: Barkfast, Bing [Bot] and 95 guests
