It is currently Wed Jul 30, 2025 2:09 am
 Post subject: Clubman Spotlights
PostPosted: Sat Sep 24, 2016 11:24 pm
Was thinking about getting a set of spotlights for my 78 clubman. Wanted to know how you guys had them mounted? I didn't really want to drill into the bumper if at all possible. If you guys had any pics of yours that would be awesome :)
Thanks, Devon
 Post subject: Re: Clubman Spotlights
PostPosted: Sun Sep 25, 2016 10:21 am
mine are mounted on a cross bar in the nudge bar
65 panel van Sprog
73 panel van Iggy
PostPosted: Sun Sep 25, 2016 12:28 pm
Perhaps modify an already damaged (so inexpensive) grille and set the lights in that, much like the LS.
viewtopic.php?f=32&t=88199
PostPosted: Sun Sep 25, 2016 1:40 pm
This is mine a few years back with the Narva 170 blues on it. Now have the hella period spots with 130w bulbs. Mounted to the engine bay sill/valance thingy at the bottom and behind the grille.
The first pic is the Hellas, second the Narva lights
Rob Forsyth
Miniot!!
PostPosted: Sun Sep 25, 2016 8:57 pm
Beautiful clubby Rob.
PostPosted: Sun Sep 25, 2016 11:19 pm
Ta mate. Long way to go though...
Rob Forsyth
Miniot!!
PostPosted: Mon Sep 26, 2016 12:45 pm
I'm thinking about using the bumper mounts themselves for 4" spots. they might obscure the headlights a bit though, i'll have to see once ive hooked a battery back up. otherwise I like the idea of making up a bracket that will mount in a similar spot to CPOCSM's Clubman and putting the bumper back on.
PostPosted: Mon Sep 26, 2016 3:26 pm
Great little mini there Jim.
The brackets are from autobarn and bought them a long time ago...I stopped the spottie wobble by bracing the valance to the subframe with a strip of steel under each bolt and a screw in the subframe...
Hooroo
Rob Forsyth
Miniot!!
