It is currently Tue Jul 22, 2025 3:33 pm
 Post subject: Fuse ratings
PostPosted: Sun Oct 16, 2016 6:47 am
While I was wiring up my black box to the fuse box recently I noticed my two fuses were only 20 amps and when I looked the Electrical section of the workshop manual it stated 35 amps, is this correct ?
 Post subject: Re: Fuse ratings
PostPosted: Sun Oct 16, 2016 7:09 am
Yes, 35 is correct. 20 are too small.
PostPosted: Sun Oct 16, 2016 8:36 am
Thanks again Dr
PostPosted: Sun Oct 16, 2016 7:42 pm
What is there in a standard mini that requires 35 Amp to run? 35 amps it too high and unsafe even though it was the manufacturer's idea. 20 amps is ample and safer.
"Let us remove your "SHORTS"
PostPosted: Sun Oct 16, 2016 8:23 pm
The original fuses were Lucas 17/35, designed to run at 17 amps continuous and will go up to 35 amps before blowing in 1 second. The 20 amp AGC will run at 20 amps and blow at 40 amps in 1 second. Either one will be fine.
PostPosted: Mon Oct 17, 2016 6:54 am
Seems to be a couple of different thoughts here, should I change them to 35 amps or leave them as is
PostPosted: Mon Oct 17, 2016 9:00 am
The way I see it, what do you want to go first the fuse or component. If 20 is working then use 20, if they are blowing you can try a 35, or something is wrong.
Nick
PostPosted: Mon Oct 17, 2016 9:03 am
Got 20's in mine, no problems so far (3 years?)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
At least if you blow a fuse, the headlights still work. :) They are unfused originally.
PostPosted: Mon Oct 17, 2016 9:09 am
So was the ignition!
I suppose the thinking was if it couldn't drive home, then let it burn :lol:
PostPosted: Tue Oct 18, 2016 6:54 am
Thanks all
I think I will leave the 20 amp fuses in and see what happens
PostPosted: Tue Oct 18, 2016 7:01 am
glenndunn wrote:
Thanks all
but keep some spare "factory recommended" fuses in the car :idea:
