It is currently Mon Aug 11, 2025 10:38 pm
 Post subject: Engine Numbers
PostPosted: Sat Oct 29, 2016 3:39 pm
Hi All
My MkII S has the correct prefix (9F/XE/Y) but the actual numbers are very difficult to make out.
There's no way I'm tampering with the authenticity of this engine by restamping them.
Does anyone have a method to extract or make visible the engine numbers if they've been mostly removed after the block has been machined?
Dave
"64 Smooth Roof Van (Colin)
Last edited by captainwaldopepper on Sat Oct 29, 2016 6:27 pm, edited 1 time in total.
 Post subject: Re: Engine Numbers
PostPosted: Sat Oct 29, 2016 3:43 pm
paper and pencil?
lay paper over the number and rub the pencil over the paper to reveal the number
PostPosted: Sat Oct 29, 2016 3:56 pm
I used some wet and dry and battery acid to get the numbers on my last car.
I can post a before and after when i get home tonight. I was in the same position last year and did a lot of googling and asking around and was surprised at the battery acid suggestion.
PostPosted: Sat Oct 29, 2016 6:08 pm
A bit of chalk works sometimes too.
PostPosted: Sat Oct 29, 2016 6:28 pm
Tried the paper/pencil and chalk but no good unfortunately.
GTO-how long do you leave the battery acid on for?
Thanks
Dave
PostPosted: Sat Oct 29, 2016 6:47 pm
I tried leaving it on for a few hours and not much happened. Then i used wet and dry (with gloves) and the number came up. The pad on mine was rusty as well. I also tried a range of other things that i had in my shed like rust convertor and wd40. I may have been lucky that my pad was rusty and removing the rust made the number appear.
PostPosted: Sat Oct 29, 2016 6:48 pm
Another car forum mentions acid (but no details on what acid and for how long), and also some support for a brief blast with a blowtorch as a way to make the shaved numbers reappear.
Perhaps try a few Google searches. :wink:
PostPosted: Sat Oct 29, 2016 8:19 pm
I have the same issue i used steel wool then wrote over the top of the number with a sharpie then steel wool again and you can see it fairly well
1968 Morris Mini Cooper S
PostPosted: Sat Oct 29, 2016 10:07 pm
Here are my before and after photos but I think my issue was more rust than machining.
PostPosted: Sat Oct 29, 2016 10:30 pm
Perhaps if you can swab acid onto the clean (wire brushed) engine number area then remove all excess such that acid is only remaining in the number indentations MAY show an improvement? I'm a bit skeptical to be honest. Because to to improve the resolution of the stampings you basically need to increase the depth of the stamps with respect to the deck surface. Be careful with your experimentations...!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Oct 30, 2016 2:23 pm
Thanks for the tips everyone-the best result has come from a black texta and steel wool.
If you squint and look out of one eye you can almost see the numbers!! (it's meant to be 55629)
Dave
PostPosted: Sun Oct 30, 2016 5:43 pm
It's a pity some engine reconditioners can't leave the pad alone when they deck the block.
It doesn't take much effort.
PostPosted: Sun Oct 30, 2016 8:18 pm
Glad to see I could help
PostPosted: Mon Oct 31, 2016 1:51 pm
Jim Liseo worked on the BMC engine line from 1959 to 1971. He told me a few weeks back that often mistakes were made during the block stampings & that the police were able to find an altered stamping up to 3/4" deep! - Hence, when an error was made, the incorrect number/s were ground off & the correct number/s restamped, but each of these blocks then had a "map of Australia" stamp added at the end.
Perhaps the police still have this technology to rediscover you engine numbers???
PostPosted: Mon Oct 31, 2016 2:21 pm
I have seen lots of engines with the Aust Flag on the end and always wondered why. They look just like other factory stampings so i dont think they are restamped.
Edit - more info at this post viewtopic.php?f=2&t=101690%20-%20p1067944
Users browsing this forum: No registered users and 244 guests
