It is currently Sat Aug 16, 2025 1:09 am
 Post subject: Thermostat
PostPosted: Fri Nov 11, 2016 12:57 pm
Which order doea the thermostat go in? The book isnt mega helpful. Do i need a gasket between the head and the engine steady? Does the steady go on top of the thermostat cover?
Sent from my SM-G900I using Tapatalk
 Post subject: Re: Thermostat
PostPosted: Fri Nov 11, 2016 1:29 pm
Head then gasket, then engine steady then another gasket then thermostat cover
PostPosted: Fri Nov 11, 2016 4:10 pm
Head, then thermostat, then gasket, then engine steady, then gasket then thermostat housing.
The head should have a groove around it where the thermostat sits into
Or to be more precise:
Head then thermostat, then gasket sealant, then gasket, then gasket sealant, then engine steady, then gasket sealant, then gasket, then gasket sealant then thermostat housing :lol:
Lillee - 1969 Morris Mini K
PostPosted: Fri Nov 11, 2016 4:45 pm
Oh, don't forget the sealant on the thermostat stud threads!
PostPosted: Fri Nov 11, 2016 4:53 pm
Legendary. Cheers guys. Certainly explains the leak =/
PostPosted: Fri Nov 11, 2016 11:12 pm
Not necessary if you put enough on the gasket, esp when using Permatex black or grey (silicone based)
Users browsing this forum: No registered users and 355 guests
