It is currently Sat Jun 28, 2025 8:04 am
 Post subject: Is this just the cam
PostPosted: Tue Dec 13, 2016 4:13 pm
https://vimeo.com/195414469
This miss is driving me nuts so before o knock on DRMini door has anyone got any ideas
1968 Morris Mini Cooper S
 Post subject: Re: Is this just the cam
PostPosted: Tue Dec 13, 2016 4:34 pm
Have you tried pulling off one plug lead at a time to see which cylinder is not firing
PostPosted: Tue Dec 13, 2016 8:06 pm
What plug leads are you running? If they are suppression type, put a multimeter on them to check resistance. bend them around and see if reading goes open circuit. If so it is toasted.
Anything over 5K ohm I put in the bin. New Bosch ones are 1.5-1.8 K ohm, GR's ones are lots less.
If buying new, get inductive core leads (Bosch, GR's etc), not graphited string (cheapies).
PostPosted: Wed Dec 14, 2016 12:31 pm
My car can't idle nicely under 1200rpmish?
Just up the idle to 1100-1200? (provided you check the leads etc as Kev is saying)
PostPosted: Wed Dec 14, 2016 1:36 pm
I'll check the cables tonight but I have upped the idle and adjusted the fuel mixer and this morning it was running like a demon
PostPosted: Wed Dec 14, 2016 6:03 pm
Or these are some others that I have
PostPosted: Wed Dec 14, 2016 6:04 pm
Red or Blue [FACE WITH TEARS OF JOY]
PostPosted: Wed Dec 14, 2016 6:07 pm
PostPosted: Wed Dec 14, 2016 6:24 pm
I like the wire cable type of lead, bullet proof...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Dec 14, 2016 9:40 pm
Inductive core cable is good. It is similar to the shielding found in coax cable.
PostPosted: Thu Dec 15, 2016 5:50 am
Well after a lot of tinkering "as my wife calls it" it's running a lot better but I still have a bit of pinging when it's under a bit of load
Also found a neat trick on YouTube on looking for escaping spark
Turn the lights out make the garage really dark. Run your engine get a spray bottle on mist and spray it over your leads cool and distributor to see if any sparks occur.
I found I needed to shield a couple of cables on my coil noticed they let off a couple of sparks. Love these little tricks
PostPosted: Thu Dec 15, 2016 4:56 pm
just retard it a bit...
that's a neat trick... might give that a go. I put my timing light on each lead and see if there are any gaps in the flashing
PostPosted: Fri Dec 16, 2016 7:50 am
Are you still running points? AFter installing electronic ignition I can wind mine down all the way to about 600rpm and it's still pretty smooth, but the alternator doesn't work at those speeds.
PostPosted: Fri Dec 16, 2016 8:31 am
I have retarded it and pinging gone also happily idling between 800-900 rpm
Going NIcely now
PostPosted: Fri Dec 16, 2016 8:44 am
Going NIcely now
What advance settings and curve are you running with?
