It is currently Sun Aug 03, 2025 8:51 pm
 Post subject: Gearbox Rebuild
PostPosted: Sat Dec 31, 2016 5:14 pm
Well the gearbox is all apart and is in reasonable condition
Input shaft bearing is knackered and is of an unknown brand
Question is for the Gearbox Experts
1st and 2nd gear syncro hub seems to have a lot of sideways movement on the spline before it engages the baulk rings compared to 3rd and 4th syncro hub
Is this normal or is there a spacer missing
Any good exploded drawings would be appreciated.
Or even if someone has a gearbox apart and can show my theirs
The mini website ones i looked at are a bit average
Thanks in advance
Marc :D
1970 MK2 Cooper S
 Post subject: Re: Gearbox Rebuild
PostPosted: Sat Dec 31, 2016 10:13 pm
1/2nd will move about without the box all together.
Post pics of the teeth on the gears and the Baulk rings.
Have a good look at the double row bearing and the laygear shaft. These are almost always knackered and need replacing.
I've got mine apart at the moment and will be going through it over the next week or so (too lazy to do it all at once)
Aaron
PostPosted: Sat Dec 31, 2016 10:14 pm
And don't forget to do the diff......
PostPosted: Sun Jan 01, 2017 6:19 am
Aaron
What about a photo of your main shaft showing 1st/2nd syncro hub so i can work it out
1970 MK2 Cooper S
PostPosted: Sun Jan 01, 2017 7:50 am
Thats a bit personal! :D
I'll take a pic sometime today.
Aaron
PostPosted: Sun Jan 01, 2017 10:38 am
LAYSHAFT IS STUFFED... SIDE BY SIDE WITH A NEW ONE.
DOUBLE ROW ON THE RIGHT IS STUFFED, BEARING CAGE IS BROKEN. SIDE BY SIDE WITH AN OK OLD ONE
SIDE BY SIDE WITH AN OK ONE AND THE STUFFED ONE...
PostPosted: Sun Jan 01, 2017 12:14 pm
Thanks for the pics
It looks the same as mine at the 1st/2nd syncro hub
I find it strange why there is so much play there compared to 3rd/4th
My box will be treated to all new bearings and lay-shaft
And a full rebuild of the diff
As I only plan on doing this once
As i would rather be out there driving it
1970 MK2 Cooper S
PostPosted: Sun Jan 01, 2017 4:57 pm
Yep, do it once, do it right.
I'd suggest you check the bearings before replacing them. Sometimes they will be better than new ones....
Make sure you check your thrusts, and be sure the tolerances are right.
PostPosted: Sun Jan 01, 2017 5:50 pm
She will be rebuilt better than new
Bead blasted all the alloy bits ready for a new coat of paint
I even welded up a couple of chipped fins on the case to make it look 100%
1970 MK2 Cooper S
PostPosted: Sun Jan 01, 2017 6:02 pm
Gee Gundy, never done a gearbox before, not doing it again, gutsy I say. Should be left to the experts, but good on you for having a go.
PostPosted: Mon Jan 02, 2017 6:32 am
Mate where do you get this comment from
I am a Fitter and Turner by trade and have been working on cars and motorcycles for 40 years
Have rebuilt engines and gearboxes of all sorts over the years
Rebuilt stuff more complicated than a Mini Gearbox
And i only do things once, that is i do it right the first time
My main work has been the restoration of Vintage Indian Motorcycles
I do everything in house including cylinder boring and honing to Alloy welding, etc
1970 MK2 Cooper S
PostPosted: Mon Jan 02, 2017 11:40 am
nice work a true artist :)
65 panel van Sprog
73 panel van Iggy
PostPosted: Mon Jan 02, 2017 11:56 am
Everybody has a skill, some are better than others. I recently overhauled my Cooper s box. Pulled it down three times until I was happy with it. Stuffed a new 3rd motion shaft bearing in the process.
If he wants to give it to the experts, so be it.
PostPosted: Tue Jan 03, 2017 8:54 am
Well, a paid professional expert gearbox rebuilder overhauled my gearbox and didn't do the the 2/ 3rd gear synchros properly. Of course I had removed the gearbox and taken it to him for overhaul so I was liable for removing the damned thing and refitting it again after rectification. I wasn't a happy camper....
If he couldn't get it right, I'd be reluctant to do it myself..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Tue Jan 03, 2017 9:48 am
Nice donk Gundy :D
I would be interested in your take on the hit and miss supply of replacement parts these days. You can buy a Timken in a Timken box that is inferior and liable to fail. I tend to stick with suppliers who consistently provide good quality stuff. But anyone can be caught out by the "knock offs" out there...
Cheers, Mick (ex-licorice framed, jap-crap rider)
PS you may be interested in this lot (Note: Collectors claim to the first TT in Oz appears to be a little dicey)
http://trove.nla.gov.au/newspaper/artic ... 2F15501750
http://vvcmcc.org/tt-ride/
Possibly the "first" TT in Oz??
http://www.ma.org.au/index.php?id=1663
