It is currently Fri Aug 15, 2025 11:09 pm
 Post subject: A+ engine into early 850
PostPosted: Sat Jan 28, 2017 7:39 pm
After advise on A+ 1275 into a '61 850.
I'm running twin SU carbies.
Should I use the A+ rocker cover with breather in oil cap or 850 cover with pipe?
What to do with breather that bolts onto gearbox clutch housing?
Should I run the 850 timing case without breather???
Also I have original cooper s twin SU air filter that has a pipe that looks like it connects to 850 rocker cover pipe???
Thanks
PostPosted: Sat Jan 28, 2017 9:27 pm
other than screwing with a '61 850 that I don't like the sound of...
You should probably install a PCV and let the engine breathe into the manifold, otherwise the below applies to the breather tube in the air cleaner
1/ Should I use the A+ rocker cover with breather in oil cap or 850 cover with pipe?
2/ What to do with breather that bolts onto gearbox clutch housing?
3/ Should I run the 850 timing case without breather???
1/ use the A+ rocker cover
2/ run it to a T piece with the breather on the A+ timing case and into the air cleaner or PCV
3/ definitely not... the A+ engine has a tensioner under there (I think), and the 850 cover won't have enough clearance for the double row timing chain
PostPosted: Sat Jan 28, 2017 9:58 pm
Thanks, for your answers.... I thought about keeping the '61 850 standard, but that would be a waste of a good fun car.
PostPosted: Sat Jan 28, 2017 10:18 pm
<horror> :shock: :shock: a standard 850 is a GREAT fun car! :shock: </horror>
PostPosted: Sun Jan 29, 2017 9:42 pm
You will need to flatten the A+ timing cover breather to clear the fan, in a roundy body.
PostPosted: Sun Jan 29, 2017 10:09 pm
Thanks, will do when fitting re ground cam.
