It is currently Mon Aug 11, 2025 2:14 am
 Post subject: installing bumpstops
PostPosted: Mon May 15, 2017 3:39 pm
how hard? :oops: i think the old owner removed the bumpstops on this when he fitted coilovers so it no longer likes big dips. I'd like to reinstall them however was advsied this might be a bit of a task. anyone have any tips on how to get it done easily?
i might just add, has anyone dealt with coilovers before? the old owner installed this as well. not sure though if that would cause the knocking. he said the knock was there from before.
 Post subject: Re: isntalling bumpstops
PostPosted: Mon May 15, 2017 3:44 pm
Fit hydro ones instead? They mount on the arm and strike the suspension tower. Opposite to dry ones. You would need to drill the mount's bracket out to 3/8".
Use std ones not competition, they are too tall.
PostPosted: Mon May 15, 2017 3:59 pm
hydro bumpstops? I might look into that if that makes it easier and if it means the car doesnt sound like its getting hammered going over bumps haha
PostPosted: Mon May 15, 2017 4:14 pm
Might also be worth confirming your ride height and shock valving.
Too loose and too low aren't a good combo.
PostPosted: Fri Jun 16, 2017 9:54 am
ok im getting over the gbanging noise haha.
how hard is it to install the bumpstops? I think I would like to get that done anyway. although the coils feel a little soft sometimes. but they are new so maybe have not settled.
unless anyone wants coils to swap for hi lows haha
PostPosted: Fri Jun 16, 2017 10:45 am
Buy the standard conical hydro front bump stops, not the comp ones.
They sit on the bottom shocky bolt, once you drill them out to 3/8". Hydro cars used a 1/4" bolt there but had no shocks.
PostPosted: Fri Jun 16, 2017 10:52 am
So do you have coilovers or the coil springs that replace the rubber springs?
PostPosted: Fri Jun 16, 2017 11:25 am
they were the spax ones. I almost think they are just coils that replace the springs. I should probably have a look underneath the car
PostPosted: Fri Jun 16, 2017 11:36 am
Coilovers look like this and should be height adjustable and the shocks should be adjustable too. You should be able to make them firmer
Coil replacements look like this and can be used with hi-los
PostPosted: Fri Jun 16, 2017 12:39 pm
I'll double check. greig malaure raised em for me. I think he said they were coilovers so im guessing coilovers. I'll check tonight
PostPosted: Fri Jun 16, 2017 2:06 pm
If you have coilovers, the bumpstops are part of the shock unit.
Shouldn't need external ones.
But if you have coil springs YES you need them, to avoid breaking balljoints. :!:
PostPosted: Sun Jun 18, 2017 9:07 am
yep I have coilovers.
the old owner told me the knock was there when going up on driveways.
however I still get the noise now. although now I get it when going over a big dip that compresses the suspension. and the knock is still there when I go up a driveway at an angle. Any thoughts? I tried to have a look if I could see anything bent. Cant really see anything though.
PostPosted: Sun Jun 18, 2017 10:32 am
Have you checked other things such as ball joints, tie rod ends, rack bush etc.
Those cracks don't look too nice.
 Post subject: Re: installing bumpstops
PostPosted: Sun Jun 18, 2017 1:42 pm
The stock inner wing is not designed for the stresses of coilovers..!! No wonder it cracked.
PostPosted: Sun Jun 18, 2017 1:47 pm
Do these bolt on kits need any engineering mod plate. Anyone can just but a kit and stick it in.
Users browsing this forum: No registered users and 124 guests
