It is currently Fri Jul 18, 2025 1:04 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 551, 552, 553, 554, 555, 556, 557 ... 568  Next
PostPosted: Mon May 29, 2017 9:13 am
Phil 850 wrote:
Brushed the dust off and drove it to Sydney Motor Sport Park. :D
Some people look really surprised when you cruse past them on the freeway 8)
Nice one Phil :D
PostPosted: Mon May 29, 2017 5:11 pm
just looked at it and then closed the shed door.
6 deg in the shed, and snow falling on Mt Bogong 30 K
from my place.
Alpine Mountains full of Mini's and Moke's.
PostPosted: Mon May 29, 2017 9:43 pm
from my place.
Yes, winter is on its way. tomorrow is our first day below 20 in the Valley
Temp drops fast after 5PM, makes it hard to get motivated to be in the shed
More clothes, more red Wine !!
So much to do before Rylstone.
Why is it the things that make me tick, are also the things that make me go boom?
PostPosted: Fri Jun 02, 2017 4:44 pm
I installed new wheel bearings and tie rod ends.
PostPosted: Sat Jun 03, 2017 6:25 pm
Give Ash some flowers Nick .
Put some fuel in it, drove it around for a bit of a run and then came home and pulled the wheels off and greased all of the grease nipples (including the one on the remote shift). Chucked the wheels back on and even used the torque wrench on the wheel nuts.
PostPosted: Mon Jun 12, 2017 7:23 pm
Was wondering why suspension down on left side, with no hydro fluid leaks showing until discovered weird liquid dripping off rear subframe....hydro joint was leaking so took off, cleaned thoroughly and pumped hydro back up with my trusty grease gun pump.....so nice to have suspension again.......ready to tackle McCarrs Creek road next week.....
Cooper S Mk2
Cooper S Mk1
PostPosted: Tue Jun 13, 2017 8:58 pm
Had a couple of repairs done by Mini Classic last week
So drove it to work as I do most days :)
New Clutch
New Steering Rack
Some new Brake Lines
And he found the random mis-fire that has been driving me nuts for so long (he disconnected the Rev counter) no more mis-fire.
I actually did some more digging and found a loose earth on the rev counter. I rewired the dash after it decided to smoke on the freeway a while ago where I found no less then 4 Positives and Negative cables all wired randomly.
The drive to work and home was perfect. Looking forward to it again tomorrow.
1968 Morris Mini Cooper S
PostPosted: Mon Jul 17, 2017 1:09 pm
Replaced the original ignition switch after 44 years, 4 months service...in the '73 Mini Window Van...emphasis on Van, Commercial etc.
Challenge...
Aftermarket switch had 4 wires - RED, BLUE, WHITE, YELLOW
OEM switch had 4 wires - BROWN, WHITE with Red tracer, WHITE & WHITE with Blue tracer [NO reference includes a WHITE with Blue tracer coming from the switch, so badly have 'commercial' variants been treated from the beginning]
Well,...RED would go to BROWN (battery positive), BLUE would go to WHITE with Red tracer (solenoid), WHITE would go to WHITE (ignition coil & fuse), YELLOW would go to WHITE with Blue tracer (accessories).
It worked. Hope this helps others.
PostPosted: Mon Jul 17, 2017 6:28 pm
Replaced the old paper oil filter with a new twist on one.
Used the adapter that mini kingdom sell
An easy job but timely found it easier to remove the alternator then it was easy to get to.
Note to self your replacing bolts with studs so don't forget to pic up some nuts that fit.
Now I can change the filter without too much headache
PostPosted: Wed Jul 19, 2017 6:59 pm
I just replaced the rear wheel bearings.
PostPosted: Thu Jul 20, 2017 8:15 pm
Haven't been doing much on the mini since having a heart attack the day before good Friday this year and having a stent wacked in and now get breathless alot
Hope to be at the kings school show that's if the club sends me a sticker after calling weeks ago for one if i don't get one it won't bother me at all just one less at there part of the ground
PostPosted: Sat Jul 22, 2017 6:57 pm
Spent the afternoon putting new clutch master cylinder and rebuilt BL Comps split brake master cylinder (Special Tuning part # C – AJJ 3388) back into the S refurbished engine bay. Getting the clevis pins back in never seems to get any easier. I was going to use R clips but have heard they can get knocked out if the pin turns, so ended up using normal split pins but only turned one leg down to aid removal next time (and there's always a next time).
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sat Jul 22, 2017 9:05 pm
... and some of us hope there will be a next time and we'll be part of it!
PostPosted: Sun Jul 23, 2017 9:58 pm
The only reason r clips get knocked off is people use ones that are too big. The clip should be the smallest that will fit the clevis pin and must be able to rotate without hitting the body once installed
Sent from my GT-I9505 using Tapatalk
PostPosted: Fri Jul 28, 2017 6:28 pm
Fitted a GPS HUD speedo to the wasaMatic. Because the speedo reads 10+ kmh high because of the 3.647 diff.
$48 well spent.
I don't use the HUD feature, it is just bluetacked to the ashtray so far. :)
It's angled enough to read fine.
Users browsing this forum: Goldbrocade_62 and 101 guests
