It is currently Thu Jul 24, 2025 2:54 am
PostPosted: Sat Aug 19, 2017 9:13 pm
Hi all
I picked up complete working engine, and was wondering what things are easily replaced while the engine is out but a nag once the engine is in.
It's a non s 1275, with 1.5 SU, and LCB. Remote box.
Is there anything that's prone to leaking oil? I hate leaking oil.
Thanks peeps
PostPosted: Sat Aug 19, 2017 10:57 pm
Maybe the primary gear seal. Impossible to do in the car without the special tool...but then if it doesn't leak no point pulling it out I suppose.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sat Aug 19, 2017 11:57 pm
Replace all seals in engine and gearbox
bypass hose, lower radiator hose
waterpump
clutch
PostPosted: Sun Aug 20, 2017 7:50 am
waterpump
clutch
Crank
Rods
Pistons
Came shaft
They're all easier with motor out. :D
PostPosted: Sun Aug 20, 2017 11:09 am
Thanks all.
It's not a rebuild thread, nor it there anything that needs changing. I could drop the engine in and it'd probably go for years without a problem.
It's more that I have it out and I want it back in pronto.
If something busts and it's an engine out job, thats fine.
I was specifically looking for something that fails regularly, which requires the engine to come out.
PostPosted: Sun Aug 20, 2017 11:13 am
Yeah that's a good one. I'm not sure it's causing problems. Is there a way to check without pulling the radiator off? But if I replace the water pump then it's an easy check I suppose.
PostPosted: Sun Aug 20, 2017 1:49 pm
The primary gear seal is at the clutch end, but if you are refitting your original 'box and primary gear cover, the primary gear seal is set in the large hole in the primary gear cover and is easy to replace once out - used to be orange coloured but now not always. The common leak at the radiator end was the half-moon seal between the gearbox and the front engine bearing cap. But that seal will be replaced when the box and engine are joined.
PostPosted: Sun Aug 20, 2017 2:52 pm
The common leak at the radiator end was the timing case cover seal.
PostPosted: Sun Aug 20, 2017 3:16 pm
Welsh Plugs
