It is currently Tue Jul 22, 2025 1:49 am
PostPosted: Sun Aug 20, 2017 3:57 pm
Can anyone tell me if the finer thread easyout is stronger because it has more threads biting into the broken bolt or is the course thread stronger because it bites in deeper. Or are they much for muchness?ImageImage
PostPosted: Sun Aug 20, 2017 6:38 pm
The best one is the one that'll remove the broken bit of the bolt. I've also got a set of straight flute ones, that i find to be successful.
PostPosted: Sun Aug 20, 2017 9:04 pm
Now this just a theory but,
I think the finer thread ones may "screw" into the hole in the bolt and expand the bolt making it tighter in the hole it's in.
The coarser ones may still screw in but are leass likely to expand the bolt.
Just by opinion :)
PostPosted: Sun Aug 20, 2017 9:37 pm
I was going to get stuck into a broken bypass fitting in a MK1 S head. I have 3 kits and they only go up to No.5 which bottoms out. I will have to buy a No.6 before I go any further.
PostPosted: Sun Aug 20, 2017 9:49 pm
they're scary.... they're really hard, so very brittle... if it's broken because it's rusted in, then they can easily shatter and leave you with a much bigger problem. Whenever I have something I can't get out, I do what Dr Mini says and drill it out, then put a tap through it....
PostPosted: Sun Aug 20, 2017 10:29 pm
Hope its not too rusted in. The head was recoed about 15 years ago and the bypass fitting was cut off for some reason. Do you use a 9/16" drill and a 5/8" UNF tap?
PostPosted: Mon Aug 21, 2017 12:00 am
I haven't used the finer thread ones to judge their success, but had good results with the coarser ones; they really bite themselves down into the offending bolt as they wind it out. I've also tried the straight fluted ones mentioned in a previous reply, with little success.
PostPosted: Mon Aug 21, 2017 6:34 am
I have some straight flute ones, you knock them in after drilling appropriate size hole, also in kit. Seems to be better for softer metal bolts.
PostPosted: Mon Aug 21, 2017 9:36 am
try snap-on sr40k 4 piece set, drill hole belt in and turn out
PostPosted: Mon Aug 21, 2017 10:38 am
Milatsmadmini
Left threaded drill bits! I had an ezyout snap on my during the week and was a crap time trying to get it out. Ended up drilling out and putting a threaded stud with double locknuts instead of replacing the bolt.
PostPosted: Mon Aug 21, 2017 11:09 am
If it was a Alloy head https://www.youtube.com/watch?v=fqZYgReuywM
and probably not the best way to doo it but still https://www.youtube.com/watch?v=jnF9_LotHCU
Nick
PostPosted: Mon Aug 21, 2017 12:37 pm
that's what I'd use, the chart says 14.4mm drill for tapping at 81%, 9/16" is 14.3mm, so yeah, that'd be a good choice. It shouldn't touch the sides and as long as you can get the tap to start, it'll peel it out nicely
or ask Dr Mini
PostPosted: Tue Aug 22, 2017 2:37 pm
If you really must use an easy out, drill the biggest hole you can get away with and use the biggest one you can fit. If one breaks off in the stud, you'll never drill it out.
I'm waiting for a left hand drill set to arrive. I've heard many people say that just the heat and vibrations from drilling the stud is often enough to loosen it, and it will screw out on the drill bit.
Here's hoping!
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Aug 22, 2017 10:45 pm
With respect to the fine v's course fluted ezyouts, I think the same as Phil850... the fine thread will be more likely to expand the fitting into the thread.
That said, I have broken enough ezyouts in my time that I would incrementally drill the fitting out and clear the thread. I did this earlier this year, and even used the correct 'special' tap to clean the thread out.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Tue Aug 22, 2017 10:53 pm
I think i will give the easyouts a miss this time. I don't have the correct size anyway so i might as well spend the money on a tap. Thanks for all the feedback.
Users browsing this forum: No registered users and 121 guests
