It is currently Sat Jul 19, 2025 2:31 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon May 30, 2005 5:13 pm
yeah because we all have a 20mm plate kicking about
Expert in training
PostPosted: Mon May 30, 2005 5:56 pm
thanks makka btw, thats the attitude i usually see here on ausmini
Expert in training
PostPosted: Mon May 30, 2005 6:54 pm
Now I wouldn't recommend it but,
and it IS only done in an emergency,
AND it will probably lead to the wrath of many mechanics
Buuuut,
If you don't have a puller, I saw a guy once in the same predicament put a sturdy piece of timber onto the back of the flywheel via the starter motor hole.
He bashed at it with an equally sturdy hammer once or twice, rotate the flywheel 1/3rd of a turn and repeated. After about 5 turns the flywheel popped off.
No piece of timber and hammer would approach my machine though.
Far too dodgy.
PostPosted: Mon May 30, 2005 7:21 pm
We were going to lighten Chong's spare flywheel, until we saw all the bruise marks on the back, where people had been hitting it with a VBFH and NO block of wood, but a lump of steel instead! :shock:
So I gave him another one.. :wink:
Cast iron is brittle stuff- hit it hard enough, and it'll crack. Then if you rev it enough, it'll blow apart... and you have a front row seat! :cry:
A decent (ie thick) puller is the kindest way to get it off the crank.
PostPosted: Mon May 30, 2005 7:25 pm
hehe.. alot of people have said that.. but my engine is seized (hence the whole exercise), so i cant spin the flywheel
Expert in training
PostPosted: Mon May 30, 2005 10:19 pm
Yeah make your own is the best bet - tho the Docs 20mm plate is a bit over kill :)
Mine only uses 1/4"
The pullers you can buy aren't worth their weight in scrap metal IMO
PostPosted: Tue May 31, 2005 7:22 am
Mine only uses 1/4"
In 40 years this puller hasn't yet failed to get a flywheel off... works for me!
Plate needs to be at least 1/2" thick... :wink:
PostPosted: Tue May 31, 2005 10:47 am
morning all, any news on the postage makka?
anyone here in perth have a couple of cheap pot joint driveshafts and a rod change linkage?
Expert in training
PostPosted: Tue May 31, 2005 1:18 pm
someone once showed me that you can bash on the end of the crankshaft bolt, I tried it, it worked, but I'm not gonna do it again..... wasn't a happy experience, I don't think any damage was done, but still... go the puller
PostPosted: Tue May 31, 2005 6:31 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
sorry mate had to work today will try again in the morning
give me a ring 0412 938 072
makka
PostPosted: Fri Jun 03, 2005 3:21 pm
If you can't get another rod, drop the one I gave you back down & let me know how long you want it to be :-p
Mike
PostPosted: Fri Jun 03, 2005 8:30 pm
cheers mike
just the driveshafts then makka
Expert in training
PostPosted: Fri Jun 03, 2005 10:37 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ok will get onto it tomorrow arvo i have been home sick with the flu
makka
PostPosted: Fri Jun 03, 2005 11:06 pm
Oh you poor little puppy, Myles.
:lol:
Ah crap that made me laugh.
Oh oh... now i have to pay the consequences. :shock:
PostPosted: Fri Jun 03, 2005 11:09 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
willy just be glad there are 1400 klm's between us
although when my cousin gets married i will be down there
makka
