It is currently Fri Jul 18, 2025 10:38 am
 Post subject: Smokey
PostPosted: Fri Jul 09, 2004 2:41 pm
Hi There guys, im having a few problems when driving the mini done the motorway or just driving done any road, every now and then some smoke pours out of the exhaust but i can see it in the rear veiw mirror but can not tell if it is white smoke or if its blue smoke. if it is blue smoke what would be the case of this happening??
any help is required.
PostPosted: Fri Jul 09, 2004 5:26 pm
When does it blow out the smoke. After you go down a hill and then put your foot down again. If so it has worn rings/bore and needs a rebuild if not then Not to sure what else it could be.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Jul 09, 2004 7:35 pm
Blue smoke = oil being burned. It can either get up past the rings & pistons if worn, or more commonly- down the valve guides. This shows mostly at the bottom of a hill, or after prolonged idling.
Can be either worn valve stems & guides, or hardened valve stem seals(1275 ones- either Mini or Rover Metro don't seem to last long).
If rings are stuffed/bores worn, it will usually blow lots of blue smoke under acceleration or load..... :cry:
PostPosted: Fri Jul 09, 2004 9:45 pm
yup, I'll also offer another piece about the valve stem seals. If they're worn, its highly likely you'll get a good puff of blue smoke when you first start the engine, as a result of the oil running down the valves with the engine stopped. as soon as ya start it the oil gets burnt, and a wonderful cloud appears
PostPosted: Fri Jul 09, 2004 9:57 pm
Mine blows a cloud when I blast off after sitting at the lights for a while, it's got brand new US made Viton seals on the intakes. I reckon the LCB is sucking it down the exhaust guides at idle (1200 rpm)- I don't seal the ex guides because they're bronze and could seize with no lube.
