It is currently Fri Jul 18, 2025 1:40 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 552, 553, 554, 555, 556, 557, 558 ... 568  Next
PostPosted: Fri Jul 28, 2017 8:24 pm
Took car for a run yesterday and noticed the Battery Gauge was reading too high , (above 15.0 V ) so sorted that this morning with another Ext regulator , back to 14.3 V , then put it up on stands , gave it an oil change .
Will give it a grease on Monday , a quick check of the tune and it should be good for the Rylstone Run .
PostPosted: Sat Jul 29, 2017 6:47 pm
Put the finishing touches onto the Cooper S after someone turned right, directly in front of me at an intersection.
PostPosted: Sat Jul 29, 2017 7:07 pm
Bugger :cry: , at least it was repairable .
PostPosted: Sat Sep 02, 2017 8:43 pm
Got the dark blue 850's engine back from Matt Read a few weeks ago. Got it in and running, yay!
Today I hope I have fixed the water leaks. I can't wait to drive it.
PostPosted: Sat Sep 02, 2017 9:42 pm
Got the rego inspection done.
I did 126 miles since the inspection last year :(
It's so much fun to drive, I just don't know why I don't do it more often :lol:
PostPosted: Sat Sep 16, 2017 10:24 am
Fitted a GPS HUD speedo to the wasaMatic. Because the speedo reads 10+ kmh high because of the 3.647 diff.
$48 well spent.
I don't use the HUD feature, it is just bluetacked to the ashtray so far. :)
It's angled enough to read fine.
Can you send a photo and where are these available, thanks Doc.
PostPosted: Sat Sep 16, 2017 10:26 am
Did he survive the verbal abuse and thumping. Thats a nice looking car.
PostPosted: Sat Sep 16, 2017 10:29 am
To help you out, just hand her over to me and I'll ensure it gets a good floggin every weekend.
PostPosted: Sat Sep 16, 2017 10:44 am
https://www.ja-gps.com.au/Polaris/gps-s ... -hud-plus/
https://www.jaycar.com.au/heads-up-disp ... r/p/LA9023
PostPosted: Sat Sep 16, 2017 3:20 pm
$48 well spent.
This one, but bought local for A$48 but no longer listed.
https://m.ebay.com/itm/Universal-GPS-HU ... 2543141376
Compared to my TomTom the reading moves around more, perhaps it uses less satellites.
But it's worth it, particularly in suburbia.
PostPosted: Sun Sep 17, 2017 9:51 am
Thanks Doc and 9yatah.
PostPosted: Sun Sep 17, 2017 10:27 am
We use a "HillSpeed" HUDo9 Digital speedometer. We use this on our longer trips and it works very well.
We did get it of Ebay, as it was cheaper than buying from (Bogaard Distributors)
PostPosted: Sun Sep 17, 2017 3:08 pm
Got these back the from the painters the other day so i got to put them on!! Love em to bits!!
I dont like oil leaks
PostPosted: Sun Sep 17, 2017 3:45 pm
Changed the oil and filter, modded the bonnet hook to clear the oil cooler, modded the bonnet latch to clear the airfilters and made an adjustable oil pressure relief now runs 65 psi cold and 55 psi hot idle. Found I have oil being blown out the dipstick but not sure what to do with that just yet, hopefully after a few hundred k's it settles down as it's only a fresh engine.
PostPosted: Sun Sep 17, 2017 8:36 pm
They are truly beautiful :wink:
Users browsing this forum: Bing [Bot] and 101 guests
