It is currently Fri Jul 18, 2025 3:00 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 12, 2009 8:03 pm
Excellent presentation.
For those interested, a reminder, I have a pdf copy of an SU tuning manual that I am quite happy to pass on.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Thu Mar 12, 2009 8:21 pm
its on the boil Bloke :wink:
Do you by chance have any pic's to add :shock:
PostPosted: Thu Mar 12, 2009 8:25 pm
nup I dont have that car i wrote that for anymore
PostPosted: Fri Mar 13, 2009 7:50 am
AEG163job
Some info for you.
Some info on setting float levels for HS2/4 carbs.
There are 4 different float types
1/. Brass float from late 50s found on Minor 1000, Austin Lancer etc. These use a different float chamber lid to later carbs. Geometry is slightly different. IIRC Needle and seat extends further out than later types.
2/. Replacement plastic float for brass floats. These have a straight metal arm. (No dogleg)
3/. Later type plastic float with the metal dogleg arm. The original type float found on most OZ minis.
4/. All plastic float- supposedly not adjustable.
The setting for types 3 and 4 is 1/8" - 3/16" with the lid assembly held upside down and only the weight of the float on the spring loaded needle and seat. Use some drill bits 1/8" goes in 3/16" doesn't on a go/no go basis.
To adjust type 3 bend the arm.
To adjust the Non Adjustable all plastic float you use 0.010" thick aluminium spacer washers between the lid and the seat. There is even a BMC part no for these washers - AYB0377.
Can't remember the setting for the brass float.
Hope this helps
RonR
 Post subject: Re: SU tune procedure
PostPosted: Mon Oct 09, 2017 4:07 pm
"....Nice work, but I was hoping to see some info on setting float chamber levels - HS2/4..."
Do you not set the plastic float height using the little brass washers (that usually ..sometimes?? ..come in the packet with the new float needle) under the needle????
Cheers, Ian
PostPosted: Mon Oct 09, 2017 5:42 pm
Ian,
The washers were aluminium in the last kits I bought.
With the newest plastic float and NO shims the float level was too low. I had to machine .020" off the needle valve's threaded end. :roll:
PostPosted: Mon Oct 09, 2017 7:44 pm
What ever happened to the bloke and his Moke?
