It is currently Mon Aug 11, 2025 8:10 pm
 Post subject: Alloy Cleaner
PostPosted: Thu Dec 14, 2017 7:21 am
Does anyone know of a good alloy cleaner for my soon to arrive Dellortos or do I need them hydroblasted
Cheers Ian
 Post subject: Re: Alloy Cleaner
PostPosted: Thu Dec 14, 2017 7:45 am
DO NOT use Molasses!
(unless heavily diluted, and even then, thoroughly rinse clean)
PostPosted: Thu Dec 14, 2017 8:07 am
Supercheap bulk degreaser, mixed 1:1 with water. Do NOT use neat! Soak for a few hours, use a hand bristle brush to get into nooks and crannies. Then rinse well with water.
I will send you a pic off phone of how mine turned out. ;)
Pics sent.
PostPosted: Thu Dec 14, 2017 10:17 am
Thanks guys. Yep that works well :D
Off to Supercheap tomorrow Kits coming
PostPosted: Thu Dec 14, 2017 6:03 pm
Supercheap also sell a few different types of aluminium/alloy cleaners which work quite well , use a toothbrush to get into the tight areas :D
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Thu Dec 14, 2017 7:08 pm
Thanks guys Couriers work weird Went from Wagga to Melbourne Sydney tonite Ill have em tomorrow or monday at Newcastle lol
Four weeks holiday Bike riding get fit get things done Life moves on as it must
They are here a matching pair unmolested .WD 40 on mixture screws on first carb released them but was a bit scary.
The other one is scarier Leaving soak with WD 40 and maybe a heat gun .If all else fails I have a saviour :D
Off too Autocheep to get degreaser tomorrow. Chokes appear to be 32mm.Wonder if the ports should be 32mm
New pot joints here Getting close.
PostPosted: Sat Dec 16, 2017 10:11 am
Following Doctors orders Off for lunch for a few hours lol :)
PostPosted: Sat Dec 16, 2017 10:20 am
If it has the fine thread recessed brass screws and the screwdriver slot is damaged, use a hacksaw to cut down through the tower to cut the slot deeper. Then screw out with wd40 and a hot air gun if needed. Then buy a new screw from eurocarb UK.
Worked on my 45DHLA, years ago.
If the M7x0.5 thread in the body is stripped, I can fix with a brass insert.
PostPosted: Sat Dec 16, 2017 12:38 pm
Thanks mate If I fail I will go back to the doctor lol Thanks bud
PostPosted: Sat Dec 16, 2017 1:12 pm
Came out dark grey after two hours Beer with mate lol.
I discovered the black stuff is water soluble Now in kitchen sink in hot water and dishwashing liquid a mild bipolar solvent
This will be good Lucky no woman here haha
I bought a brand new screwdiver and freeze release spray One is ok One is a biatch .Toolies and soopercheep
PostPosted: Sat Dec 16, 2017 2:06 pm
That failed white vinegar and water doesnt Pics coming soon The Supercheep is alkali I may have left it a little long The white vinegar is mildly acidic and i can scotchbrite it and get a nice result I am letting them soak in the sink again.This may take overnight but its working I have black crap on my hands and the carbs will come out beaut .I hope the plastic floats survive the trauma lol This process may get in them fine threads and help my dilemma. If I cant do it I will refer to a surgeon
No one here saying get that out of my sink lol Hope this helps someone.Next time dont dilute the white vinegar This may take days now but will be a good result.
Dilute chemicals take longer to react I didnt realise now potent the supercheep stuff was .Will post results and hopefully dont need surgery
PostPosted: Sat Dec 16, 2017 5:35 pm
They arent black no more like Robs eye will be when he sees the big fat fella Going real well :D
If anyone needs advice on this give me a pm .This process works. The water in my sink is dirty.
Even the butterflies are cleaning up Wow
Thanks Kev I aint no engineer just a bloke with one main trade and learnt others through mates and night courses
I crap myself when they were black but its easy reversed.. The Supercheep stuff is alkali and it formed black crap I realised I had to go mild acidic White vinegar
All clean used Loctite Freeze and release and the mixture screws releases...Just
Waiting on kits now The float retainer pin looks flimsy
PostPosted: Sun Dec 17, 2017 2:42 pm
I think Devcon would fix broken float holes I knew a bloke 12 ported six cylinder Holden heads using Devcon It was fine with petrol but no good with methanol and speedway Same guy did my 940 head and did it wrong with big shiny ports to impress me and used 1100S intake valves as he said it would be unreliable to use 1.401.Well I got a mate to fix that and we put the bigger valves in .Pity the ports werent just cleaned up.The S has a 286 cam 1.5 rockers and is a pig down low Hell breaks loose when it comes on the cam
Sorry for going off topic but its all experience
PostPosted: Sun Dec 17, 2017 3:49 pm
An update Use Kevs advice with supercheep degreaser on carbs. Two hours with a 50/50 mix cleans the crap out of em Mine went grey black Rang the Doctor panicking.
I soaked em overnight in white vinegar and water good result .Still not happy went to Coles and used straight white vinegar Yepee Tomorrow a sink full of white vinegar and they will be like new.Scotchbrite helps but im a lazy crap.Done as much scotchbright as I can handle.Use straight white vinegar after Docs method
PostPosted: Sun Dec 17, 2017 5:33 pm
Twenty bucks worth of chemicals Im a happy man and the screws are loose like me :)
No woman here to say get that out my sink but i met a nice lady today
Users browsing this forum: AWOODY and 173 guests
