It is currently Mon Jul 28, 2025 12:25 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
 Post subject: Hydro sag
PostPosted: Sun Jun 05, 2005 4:15 pm
Pops seems to have a bit of a lean to the left.
I'm not sure if you can see in the pic but he leans to the passenger side.
When I jack up the rear, the passenger trailing arm moves up and down, the drivers side is as stiff as......well....you know....it doesn't move.
Ideas??
PostPosted: Sun Jun 05, 2005 4:17 pm
Anton................ i can see the old buggers sagging %^$& cos i can't see the pic :cry:
I got nuthin......................
PostPosted: Sun Jun 05, 2005 4:45 pm
Resident Haemorrhoid
maybe Pops is compensating for the driver :wink:
the Hydros are seperate circuits(left and right) I had the same problem either had to put up with it or go rubber cone :(
after getting sick of getting it toped up at $30 a pop I had it converted to the rubber cone setup and very happy with how "Taz" is handling now. :D
Gadget
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Jun 05, 2005 4:47 pm
Can see now........ hmmm interesting, Slidey has been reconditioned and he leans ever so slightly to the passengers side like the popsmeister :?
PostPosted: Sun Jun 05, 2005 4:57 pm
That means it's adjusted for us portly types.
It'll settle back to an even keel once I get in it... :oops:
PostPosted: Sun Jun 05, 2005 5:20 pm
I can pump it up for you if you bring it to adelaide!! :D
PostPosted: Sun Jun 05, 2005 6:55 pm
If the RH trailing arm doesn't move it's seized on the shaft, or the knuckle joint has had it. Easy fix either way.
:idea: Has the car been greased since you got it??
If it's not lost fluid, the bags are fine. I'd convert to dry as a last resort. Already got a Deluxe that's been `done'- don't go there... :lol:
PostPosted: Sun Jun 05, 2005 8:41 pm
hmmmm.....I just crawled out from under him...... :?
I can't see any major probs with the suspension components. To be honest, it looks like the hydro on the passenger side has gone down, and the drivers side is still at the correct height.
It was pumped up recently to perfection.
Kev, :oops: I haven't greased Pops since I 'found' him......It's been on my MUST DO list, but I just can't find the time to do it! He doesn't get driven much anyways.
PS: I am this close " " to saying 'I'm sick of it all'...... :cry: :evil:
PostPosted: Sun Jun 05, 2005 8:50 pm
Ah, then you are at the best stage of the "mini life cycle" as i call it.
it gooes
yay,i have great minis
to
wow my minis are driving so good
to
that probl;em seems to be getting worse
to
i should fix that prob
to
mini broken
to
I am this close to saying im sick of it all (this is the complete bottom of the barrell)
to
YAY SOMETHING GREAT HAS HAPPENED IN THE MINI WORLD (which in your case will be JAM completed) which is the top of the cycle.
So you see, the stars predict something good will be comming soon in the mini world for you Anton@
PostPosted: Sun Jun 05, 2005 9:01 pm
It may not be the left that is sitting down, it might be the right sitting up because of the stiff trailing arm bush. :?
PostPosted: Sun Jun 05, 2005 9:10 pm
Morrie...I reckon you are right.
Chris, I have started my 'i am depressed' thread in General Chat. By the way, I AM depressed :?
PostPosted: Sun Jun 05, 2005 9:26 pm
So why do hydro minis seem to sag at the front so bad?
Can this be adjusted out without discharging the system to shim?
PostPosted: Sun Jun 05, 2005 9:38 pm
They don't sag at the front really- what happens is the rear `helper' springs stretch, and so don't help pull the back down (and the front up).
Mine isn't sagged, it's done 140,000 miles or so and hasn't even had the knuckles done yet... :oops:
You would need to let the fluid out to swap the helper springs. But no big deal if you've got a pump. It's easier than working on dry suspension really. :wink:
PostPosted: Sun Jun 05, 2005 9:42 pm
OMG.. i was going to open a hydro thread today too..!!
Mo has had a few bashes (ie cruises) and now the hydro is "flat"
Is it possible (if there are no leaks) for the fluid to be "compressed". If fluid is not leaking, how does it ultimately need "topping up"
Biggest question... Kev do you still have your hydro pump..? May have to organise a trip over to yours with a 6 pack to get Mo back to normal ride height.... :wink:
PostPosted: Sun Jun 05, 2005 9:43 pm
so are these helper springs able to be re tensioned (is that the right description?)?
Or is it a case of buying new ones if they are available?
Mick
