It is currently Sat Jul 19, 2025 12:31 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Vinegar Bath
PostPosted: Thu Jan 18, 2018 7:55 am
Just wondering where to buy large quantity of molasses!
PostPosted: Thu Jan 18, 2018 7:57 am
Animal produce place
PostPosted: Thu Jan 18, 2018 10:34 am
Horsey shop.
PostPosted: Fri Jan 19, 2018 6:24 am
Is the molasses in liquid form?
PostPosted: Fri Jan 19, 2018 7:52 am
Yes some may want you to take your own drum
PostPosted: Sat Jan 20, 2018 6:55 am
Yes , i've brought mine from our local produce store , comes in a 14 lit bucket , i think it was about $30.
PostPosted: Sat Jan 20, 2018 7:19 am
So as I understand it the recipe for rust removal on metal surfaces is
1 part molasses
1 part water
soak rusty part for good while
then wash off in clean water
PostPosted: Sat Jan 20, 2018 8:08 am
Just make sure that there is no oil or grease on the parts as the mollasses won't get rid of it .
I just do a 50/50 mix ,(it doesn't have to an be exact measurement) in a kids wheelie bin , i pour a couple of buckets of hot water in the bin first , then 1/2 the bucket of mallasses and give it a stir , then some more hot water and the rest of the mollasses and rinse the bucket out with hot water .
The bath will evaporate as well over time so you might have to top it up with tap water now and again.
PostPosted: Thu Jan 25, 2018 9:44 am
I bough 2Lt from Kirkwoods for $4.50, mixed it up about 4:1 and put it in the engine water jackets with the water pump on, will have a look after 6 days and see what it's done.
PostPosted: Thu Jan 25, 2018 2:51 pm
Cool, post up some before and after pics as an update to yours too if you can :)
Sent from my Pixel 2 XL using Tapatalk
PostPosted: Thu Jan 25, 2018 3:46 pm
Won't do much in 6 days. I would leave it in for 2 weeks, drain, flush, fill again. Look in another 2 weeks.
As for the mix, 1:2 or 1:3 molasses: water works best.
PostPosted: Thu Jan 25, 2018 5:09 pm
Some before pics
PostPosted: Sat Jan 27, 2018 6:23 pm
Another option is caustic soda to get rid of grease and the phosphoric acid dip to clean and etch for painting . Very fast turn around. Here are some arms ive done
After caustic bath:
After phosphoric dip:
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sun Jan 28, 2018 5:56 am
Hmmmm...caustic does a good job.
PostPosted: Sun Jan 28, 2018 6:25 am
Caustic - what affect on the bearings.
