It is currently Fri Jul 18, 2025 12:03 pm
 Post subject: Job for the Doc
PostPosted: Thu May 03, 2018 9:22 pm
For my build I have a Nissan Pulsar N12 turbo distributor.
A little different to the non turbo we all know.
This is good as there is no advance at all.
I am using programmed curve.
The differences are the turbo type has no drilling for the end engagement splade at all.
The end of the shaft drives it with no collar in nissan as per non turbo
You must drill a hole yikes.
Need to get phasing right .
I can do this with weak loctite.
The diameter and length are totally compatible .
The mini clamp retainer is larger in diameter than the shaft and needs a small machining job.
I will get a photo as this is a great mod.
This is hall effect rather than reluctor as per normal pulsar.
 Post subject: Re: Job for the Doc
PostPosted: Fri May 04, 2018 2:42 pm
Hole position isn't that important, you can spin the dizzy to get it right after drive dog is fitted.
PostPosted: Fri May 04, 2018 9:04 pm
Awesome Will be in touch .Im ready to degree the cam in .Wheel is coming
The stub stacks are great .
I just seen than sprocket dots lined up is number 4 on compression and number one lobes rocking.
Cheers Ian
PostPosted: Fri May 11, 2018 10:52 pm
Cheers Ian
Yes that is correct. Firing on #4.
Do NOT then install the dizzy driveshaft as per pics in manual, without turning the engine 360deg, or it'll be 180deg out.
PostPosted: Sat May 12, 2018 1:36 pm
Thanks Kev Gee that caught us a lot as young blokes :)
