It is currently Sat Jul 05, 2025 1:05 am
PostPosted: Tue May 01, 2018 9:54 pm
Got it off ebay .Its great and the original alfa link between the two carbs is better than the one supplied as my carbs are close spaced and the supplied one has to fit lots of applications and would foul my intake manifold and need modding. Its a pity its for north south motors and the pull is off to the right looking at the front of a crossflow mini.All good as the cables are super long.Full steam ahead now.
PostPosted: Wed May 02, 2018 7:30 am
Any pics?
PostPosted: Wed Jun 06, 2018 7:27 pm
Bit more done today Had to run the whole linkage package It wasnt compatible with alfa setup
Pulls from passenger side All good as cables are long enough .
Getting pushrods done Getting closer
PostPosted: Wed Jun 06, 2018 7:39 pm
Pushrod holes filed as even standard 1/4 pushrod dont line up with exhaust valves and foul
MGB headstuds worked out fine sourced from QLD.
Gemini starter motor filed ready to go
PostPosted: Wed Jun 06, 2018 7:58 pm
So much work for something that was supposed to be so easy
PostPosted: Wed Jun 06, 2018 8:20 pm
If it wasnt for a thief I prolly would have got pushrods headstuds little plate for the end
Ive written it of as a bad experience
Im making good out of bad many years later.
Wonder how all the customers rolled filing their rod holes ????
PostPosted: Thu Jun 07, 2018 8:33 pm
Have an adjustable pushrod made today
Pushrods will be correct for the application
Have a little aluminium square block locates over the ferrule for a standard mini accelerator cable
Converts it to dual cable and is reversible.Two extra quarter holes for cables .Block is threaded for adjuster on each cable.Mates that share skills.
Users browsing this forum: No registered users and 21 guests
