It is currently Fri Jul 18, 2025 1:58 pm
 Post subject: Brakes (is this bad?)
PostPosted: Sat Jul 10, 2004 5:36 pm
I noticed this when took the drum off today..
i'm guessing the bottom of that cylinder should be the same as the top...
and can i just knock it back in?
prepares fist for giggling min13K :twisted:
PostPosted: Sat Jul 10, 2004 5:41 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
HAHAHAHAHAHAHAHAHAHA
ok thats not really funny actully
the piston has poped out you will need to prolly replace the seals and give it a hone or just buy NEW ONES HAHAHAHAHAHAHAHAHAHAHAHAHAHA
:P :twisted:
PostPosted: Sat Jul 10, 2004 5:48 pm
As per your request....
:evil:
PostPosted: Sat Jul 10, 2004 5:50 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i'd take a photi of me given you the finger but i could not be ****ed
makka
PostPosted: Sat Jul 10, 2004 6:04 pm
no worries makka i got the cheeky bastard
http://www.angelfire.com/mech/ducho/DSC00077.JPG
(cut n paste)
Inconspicuously Conspicuous
PostPosted: Sat Jul 10, 2004 6:17 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
thanks dooke
get that up ya :) mc
makka
PostPosted: Mon Jul 12, 2004 10:06 am
here's what i got.. :)
<edit> ah.. ok... cut 'n paste . . i see it now :)
PostPosted: Mon Jul 12, 2004 11:12 am
probably cheaper/easier just to get new wheel cylinders dude
bout $70-$80 and pretty easy to fit
PostPosted: Mon Jul 12, 2004 12:43 pm
to be honest i dont see the problem
my brakes look pretty much like that
and the fronts were even leaking alittle on the weekend.
after a car wash with recycling bin water they squeaked a hell of alot.
just drove with the brakes on and after the water (and fluid) steamed and burned off, things are just like normal
whats the problem with your brakes MC
PostPosted: Mon Jul 12, 2004 12:50 pm
:shock: serious dude?!?! what are you gonna do if/when one of the wheel cylinders lets go? you wont have any pedal pressure and will be relying on the handbrake to stop ya! leaking brake fluid is a sign that the seals in the wheel cylinders are on the way out....not very safe
PostPosted: Mon Jul 12, 2004 12:59 pm
there were only a couple of drips on the cylinder, i bled them that same day so im not sure where it came from
brake fluid level doesnt go down, no more smells of burnt fluid,
but ill get someone to have a look at them soon, thanks
can you explain the pictures for me?
 Post subject: Danger Will Robinson!!!
PostPosted: Mon Jul 12, 2004 1:00 pm
Not to mention the possibility that one or more wheel cylinder can dump fluid onto your brake shoes, causing them to swell and/or "grab" or worce "slip" which can result in a violent spin out under moderate to heavy braking :shock: :? :cry:
PostPosted: Mon Jul 12, 2004 1:22 pm
68matic The car doesn't actually dive at the moment, so i thought i'd check over the car and catalogue the things i need to fix and when i looked at the brakes I saw what's in the pictures and it seemed wrong.. what i was asking about in the pictures was that the cylinder (piston?) was firmly stuck out... and that would give me "Single Leading Shoe Power (TM) " on the front right... would it not?
tommo: yeah i was thinking i'd have to swap it.. maybe i'll see if i can find one at wreckers.. ( alhtough i'm nt entirely sure how to remove it) :)
PostPosted: Mon Jul 12, 2004 1:26 pm
well just keep an eye on it for a few days to see if there's any more weeping from the wheel cylinders (thats the bit that pushes the brake shoes out onto the drum) if one of the pistons comes out of the cylinder (as in photo above) then there is no seal and hence nothing for the brake fluid to push against and it'll just seep out the sides and onto the brake shoes. not good
PostPosted: Mon Jul 12, 2004 10:41 pm
The shoes look missmatched to me in the pic. The upper looks like the wider variety found on twin leading brakes.. i found one on the rear passenger brake... they dont work too well as they are too wide and they dont sit perpandicular to the drum! not to mention dangerous. Also the piston shouldnt be out that far... either very worn shoe or very worn drum i would think? New wheel cylinders are only around $20-25.
