It is currently Sat Jul 19, 2025 10:58 am
PostPosted: Mon Jun 06, 2005 2:15 pm
As the topic says what are the best sort of plugs and gaps to run when you have a pulsar dizzy installed, or should you use the ones reccomended for a nissan pulsar
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Mon Jun 06, 2005 2:24 pm
Location: Melbourne, Australia (car); Savannah (GA), USA (me)
Somewhere in the original thread it stated:
"Plugs: NGK BP6ES, Bosch W6DC are also good.
Plug gaps- .040" fires OK with the stock Nissan 1.5 ohm coil to 8000 rpm"
I just reset my current plugs to a 0.035" gap for the time being, with no problems. I will change to the NGK BP6ES with a 0.040" gap next service and give it a try.
PostPosted: Mon Jun 06, 2005 5:19 pm
Plugs are always chosen based on the motor, NOT the dizzy..
Whatever plugs you have running now will still be fine. Open 'em up a bit as said. If you get any misfiring, close them back up a bit. .035"- .040" usually OK. :wink:
 Post subject: gap setting
PostPosted: Tue Jun 07, 2005 7:38 pm
Read an indepth article on plug gap and the outcome was 0.8mm.
Forced induction or NA hot or std all came back to best overall performance from 0.8mm.
I did find interesting the note regarding spark energy and duration. Seems that atomisation and turbulance was the gremlin for plug deterioration. hmm go figure
PostPosted: Wed Jun 08, 2005 10:12 am
What is a plug gap of 035"- .040" in mm
77 Leyland Clubman
PostPosted: Wed Jun 08, 2005 12:08 pm
Nope, the " stands for imperial measurment of inches, also ' stands for feet.
Edit:
Ie. 0.040" is 0.040 inches.
Ie. 3' is 3 feet.
PostPosted: Wed Jun 08, 2005 1:23 pm
0.8mm (divide by 25.4 mm to the inch) = approx. 0.032"
PostPosted: Wed Jun 08, 2005 5:48 pm
Or remember that 1.0mm = .040" near enough- (actually 0.03937") :wink:
