It is currently Tue Jun 24, 2025 10:22 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Aug 20, 2018 10:46 pm
I've partially striped my 1100 for my mini and found that the head has had a little bit of work done to it. Does anyone know if grinding down the peaks between the valves will increase the flow of the head in any significant way? I've measured the valves and they are still standard size for a 202 head.
PostPosted: Tue Aug 21, 2018 7:41 am
It would de-shroud the valve a little. I suggest having a read through GR's small bore articles on his website. They will help your understanding.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Aug 21, 2018 7:57 am
Here’s what I did with mine, no tested yet but looks like it’ll be nice.
PostPosted: Tue Aug 21, 2018 12:54 pm
you can go a *lot* further than that - you should read GR's article too
PostPosted: Mon Dec 24, 2018 4:58 pm
Was just watching this last night...
viewtopic.php?f=5&t=97974
Also, is this the GR article???
http://russellengineering.com.au/perfor ... der-heads/
http://russellengineering.com.au/projec ... -bore-pt2/
PostPosted: Mon Dec 24, 2018 8:26 pm
Read David Vizards books. They are full of accurate, useful and reliable information on everything you need to know about cylinder head modification.
Have a Nice Day.
PostPosted: Tue Dec 25, 2018 7:06 pm
Books are good
PostPosted: Tue Dec 25, 2018 7:30 pm
Can't go past GR. Best mini engine builder.
PostPosted: Wed Dec 26, 2018 8:02 am
Ian_B wrote:
Books are good
what's a book? :wink:
PostPosted: Wed Dec 26, 2018 9:24 am
I grew up reading and learning from books...great for getting your posture right when placed on your head whilst strutting about...or for holding doors open...etc etc
I read in one, that when remodelling combustion chambers by removing metal, that you are lowering the compression ratio so you need to skim head or block or use different pistons to compensate (or, after measuring and calculating your new CR, to just live with it! :shock: )
PostPosted: Wed Dec 26, 2018 5:53 pm
When I learnt music (drumming) I was taught to read . Its not needed to play but it is essential to pass things on and learn .The credibility of the book writers is unquestioned when they hide nothing.
PostPosted: Wed Dec 26, 2018 5:57 pm
The yellow bible says it all
PostPosted: Mon Dec 31, 2018 5:02 pm
What he said :roll:
PostPosted: Mon Dec 31, 2018 5:52 pm
Cam pro plus measures cams where you dont know what you got Every cam I got from Watson Jones Waggot came with a card .You knew tappet clearances timing The lot.Measurements of a modern grind ive seen was not modern at all.
PostPosted: Tue Jan 01, 2019 7:19 pm
If you dont want to have a go on your own ala Vizard take it to GR
